Sat, Feb 1, 4:42 AM CST
Renderosity Forums / Blender
Welcome to the Blender Forum
Blender F.A.Q (Last Updated: 2025 Jan 28 1:01 pm)
Welcome to the Blender Forum!
   Your place to learn about Blender, ask questions,
   exchange ideas, and interact with the other Blender users!
   Gallery | Freestuff | Tutorials
Visit the Renderosity MarketPlace. Your source for digital art content!
Subject: Importing Poser figures into Blender
ccprince ( ) posted Sun, 20 November 2005 at 6:29 PM ยท edited Fri, 31 January 2025 at 2:44 PM
I tried posting this question on elysiun.com, to a resounding silence. Of course, Poser isn't exactly popular to the serious Blender-heads. But, MakeHuman just isn't up to par with Poser.
What do I need to do to import a Poser figure into Blender? Getting the geometry in is simple -- export from Poser as an OBJ, and you're good to go. But the textures don't come through at all. I think that Blender does read the MTL file, but none of the textures get connected to the geometry. If I have to do that manually for any figure I want to use in Blender, that's just too annoying.
Can anyone here help?
jestmart ( ) posted Sun, 20 November 2005 at 10:46 PM
Most Poser Figures are made in several separate segments (groups) in order to define the "Bones" for Poser's odd ball rigging system. Often the vertices don't line up along the seams of the groups to allow you to fuse the parts back into a single mesh that you could rig with Blender. Even if you could get the figure into a single mesh the polygon count would probably be so high it make the model almost unusable.
ccprince ( ) posted Tue, 22 November 2005 at 12:06 PM
Actually, I don't care about rigging in Blender. I'm not animating anything there, just doing still images. So, once I get the pose right in Poser, I want to import into Blender for the rest of the scene modelling and the rendering. The only thing missing at this point is the textures, once I import into Blender.
larryma ( ) posted Tue, 22 November 2005 at 6:49 PM
Export figure, use only weld body seams. If you import it back into Poser, it should be a prop with no divisions. It can then be imported into Blender as a single object.
fls13 ( ) posted Thu, 24 November 2005 at 9:15 PM
There's an .obj import/export script that's better than the defaults included with Blender you can get here: http://www.zoo-logique.org/3D.Blender/scripts_python/obj_io_modif228.py
ccprince ( ) posted Sun, 27 November 2005 at 2:14 PM
fls13: I tried that script, too. I remember that it worked better than the default script, but still didn't work. I'm not sure if I used version 228, though. I might give it another try. larryma: Will that technique bring the textures along with it? Like I said, I'm getting the geometry from Poser just fine, but the model loses all its textures. Thanks for your suggestions, everybody! I'm sure I'll figure it out, eventually. Perhaps it's time for me to learn Python, and see if I can figure out my own dang script.
gezinorgiva ( ) posted Sun, 27 November 2005 at 3:34 PM
There is a obj_io_modif236,236d 236e and 236f scripts as well but none of them run without errors except 236 and then you still have to do manual stuff after.(Using 2.4a2) I had not heard about 228; Ill give it a go but I am sure it is more of the same.
gezinorgiva ( ) posted Sun, 27 November 2005 at 4:42 PM
I saved PHF as a pzz imported that into Daz exported it as an obj from there and then imported that into Blender using the 236 above and that seems not so bad.
haloedrain ( ) posted Sun, 27 November 2005 at 7:44 PM
Are the pieces still UV mapped? If so you might just be able to create a new material with the image texture and apply that to all the pieces. Kind of a pain, though, but it might work...
