Fri, Jan 31, 10:07 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Subject: Problems with Mike & Vicky Clothing
Tired ( ) posted Sun, 11 March 2001 at 1:00 AM ยท edited Thu, 30 January 2025 at 10:20 PM
Recently bought the Mike and Vicky clothing paks. Mike's clothes installs and there was no rsr of cr2 files for his tie and bow tie. Vicky's clothes install and system says it can find the obj files for her skirt or pants, I checked the geometries and librariy files all the files are present. I'm running Poser with the 403 update. Has anybody had similar problems? Any ideas for a solution? thanks - Bill R
JOE LE GECKO ( ) posted Sun, 11 March 2001 at 5:46 AM
I don't have Vicky clothing pack, but regarding Mike's CP, the tie/bow tie are smart props, so you'll find them in Props "menu". For Victoria, you should open the .cr2 files with notepad and look at the path to the .obj at the beginning of the file to check if everything is ok ?! Sometimes, deleting the .rsr file in geometry folder can solve the problem ( make a backup of these files first, even if Poser will recreate them when loading the figure :).
~DutchAngel~ ( ) posted Sun, 11 March 2001 at 8:44 AM
The problem with the OBJ files happend to me too. Only it said on my end, that it could not read the .obj files. If you have that problem than you can solve it with deleting the .rsr files from the geometries directory. If it cannot find them.. look at the settings of the .cr2 file in the character library. Make sure that the .obj files are in the exact same directory list as the rsr files says. Remember the files are case sensitive. I hope this will help you a little. :)
nitreug ( ) posted Sun, 11 March 2001 at 12:24 PM
What I do WHen I but something from one of the store is to try the item and if I got a problem then I download again the item and most of the time it fix it. I get both packs and never had this kind of problem.
