Thu, Nov 7, 11:52 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Nov 05 6:06 am)
Carrara Free Stuff here.
Subject: Veloute 2 question & problem....Thanks in advance :)
dlk30341 ( ) posted Thu, 24 November 2005 at 2:36 PM ยท edited Mon, 04 November 2024 at 6:28 PM
Let me say I tried handling this via PM, I was to embarrassed to ask here, but the instructions given were to no avail. :( So, using C5P-Beta, installed Veloute 2. It is NOT showing up in any of shader menu dropdowns. I've tried install & re-install. It is in the extension folder. I've even tried giving it it's own folder. Any ideas? Thanks in advance :)
bwtr ( ) posted Thu, 24 November 2005 at 9:53 PM
The download of Veloute (not now called 2) from the Inagoni (Julians) site for the Carrara 5 Beta comes in 3 sections which you put into place rather than the two sections which applied to Carr4. (You can't put the Carr4 one into Carr5.)
bwtr
LCBoliou ( ) posted Fri, 25 November 2005 at 12:12 AM
Make sure you are installing the C5Pro beta version of Veloute. Are you sure you downloaded the C5 betas? I did, used my Veloute C4Pro SN in C5Pro, and all worked fine. Did you have 3 files with the download -- one a .txt file?
dlk30341 ( ) posted Fri, 25 November 2005 at 8:28 AM
I think bwtr might be correct...will try that. Louis....I tried the Beta of Veloute 2 & it crashed :( Got an error saying the grid was more recent. The guy who makes these said there were 2 betas released within 5 days of each other...so they are fubared. That's OK, I can wait....in regard to C5P. Also, I don't see a download for C5P on his page...just C5. The download for C5 had ALL the plugins from the vendor in it.(Beta) Could you point me to the correct place :) Thanks
LCBoliou ( ) posted Fri, 25 November 2005 at 12:06 PM
I think I may have done you a disservice by emphasizing the "C5Pro beta," as the C5 beta is the same -- that is what I used. The 3 sections that bwtr mentioned are the files I mentioned earlier (C4 doesn't use the .txt file -- which is a script file). Sorry if I added confusion to your time -- learning a new 3D app. is confusing enough!
I did notice that the date of my Veloute betas is 10/20/05, the latest are 11/23/05. I'm going to move my older files to a safe place, and put the newer ones in -- see what happens?
BTW, I made a bunch of rocks in Vue, and imported them into C5 for distribution -- worked pretty good! Adding noise to the terrain mixed with rocks, and a "scum-line" effect produced one of the best shore-line effects I've done. Add a ripple or wave texture to a plane, then use the texture as a displacement map, and you got 3D waves -- that (I assume) can be animated. C5's distribution mapping is great; just add layers of distribution maps to a terrain texture, then use them for precise object distribution.
At any rate, this is where the plug-ins are: http://julien.chaplier.free.fr/DownloadLink/C5BetaPlugins.zip
Hope you had a happy T-Day!
dlk30341 ( ) posted Fri, 25 November 2005 at 12:11 PM
Very cool :) Off to check the update page :) When I checked earlier the date was 11/5.
dlk30341 ( ) posted Fri, 25 November 2005 at 12:27 PM
Let me know Louis what you get...still getting errors. I know it's Beta & will patiently wait for fix :) NP - no complaints :)
sailor_ed ( ) posted Fri, 25 November 2005 at 10:39 PM
I tried to install the C5beta plugins today. My files are all dated 11/23/2005. When I copy them to the C5beta extensions folder and then open C5beta I get a lot of error messages "The extension {x} is too recent" Insert "baker" or "normal" or some inagoni plugin function where the {x} is. Anybody familiar with this or do I write Julian?
dlk30341 ( ) posted Fri, 25 November 2005 at 11:11 PM
He said he had rec'd 2 updated SDK's within a 5 day period(last week) and yes they are fubared.....You need the files that are dated 10/23. I'd send him an email :) From what I gathered from emailing is he wasn't going to release any more "betas" till the SDK was finalized.
sailor_ed ( ) posted Fri, 25 November 2005 at 11:37 PM
I wonder how DCG does it?
julien_chaplier ( ) posted Sat, 26 November 2005 at 7:40 AM
Hi, You can find here another build for C5Beta: http://julien.chaplier.free.fr/DownloadLink/C5BetaPluginOld.zip for those that have the error that says the plugins are too recent. Julien
