Vue F.A.Q (Last Updated: 2024 Oct 07 10:52 pm)
That COULD be the problem, but I kinda doubt it, though I would suggest you at least give it a try. What file format are you using to export? What happens when you try to import? Does Vue crash, or give any error messages? I've been importing Poser 4 (4.03) figures into Vue 3.1 from the day I got it, and never had a problem. Use .OBJ format. Sometimes it can take a while, depending on file size, but so far the largest Poser export I've tried and also succeeded with was 80 MB. Please consider 4.03 patch--- it also will give you the option to export morph targets, which you can't do without it. Also, please make note of any error messages Vue is giving you, so we can help you. You might also try re-installing Vue-- that's fixed other problems in the past. You should not be having troubles importing Poser 4 characters, or ANY of the supported 3D formats, with the exception of any .lwo files more recent that LightWave 5.6.
Attached Link: http://www.curiouslabs.com/index.html
I agree to the above...the 4.03 update is worth the download in any case.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Hello, i'm new to all this stuff. i've got Poser 4 & i can't import figures i've done in it into Vue 3.1. what should i do ? i've seen that there's a 4.03 patch at Curious Labs website : does it solves the problem ?? (want to know before because it's a huge file & i've got a slow connection !) thanx to all
