Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 7:37 am)
Attached Link: http://www.physicalc-software.com/forum/
Mmmm, yes, more details needed pls.... You will get a quicker response to your questions at the PoserPhysics help forum (see link above).Creator of PoserPhysics
Creator
of OctaneRender
for Poser
Blog
Facebook
Sorry it took so long to get back, The error I get is Attribute Error:'NoneType' object has no attribute 'World Vertices' I get this whether I use an object or a figure, after it trys to run the script. skee
NOTE: No trees were killed in the sending of this message, but a
large
number of electrons were terribly inconvenienced.
Skee - this is because the is an extra FocalDistanceControl in your scene (your start scene is slightly corrupt - you can check the pz3 file to verify this). I've got a patch to fix this, which should be available in the next 12hrs. In the meantime, make sure you start off with a completely blank scene.
Creator
of OctaneRender
for Poser
Blog
Facebook
It happens (among other things probably) with some of Miki's hair/clothes. I can use a nude Miki, but clothed, I get that error too (AND an extra focal distance prop)
Am I the only one that is having this problem? I can't seem to do anything to get it to work. Is there a step by step on how to do this? I have reloaded everything and still it will not run the script, still get ..Attribute Error. skee
large
What character are you using? Try a James Casual. He hasn't got that Focal point error at least, I played with him all day yesterday. Have you restarted Poser? (probably a silly question, but...) Try "Reinitialize Pythion" in the File menu and see if that helps? Also how are you running the script? With the thingie in the Porps folder or just by running one of the python scripts included (I had played with it for several hours before I found that Python Loader thing LOL That's what you get for not reading readme's...)
ernyoka1, Thanks for the reply, I have tried Jessie and James and have had the same things happen. I reloaded poser6 with all the updates and reloaded the python. I have been running the python using the loader thingie. I will try to load James Casual and see what happens. I checked the forum and found that some poeple are having this happen to them ....sometimes. It's bound to be something I am missing because the pre made ones work just fine. ( the sample files) skee the lost
large
Transfering Scene to Physics Engine... Creating ground plane Traceback (most recent call last): File "", line 17, in ? File "C:Program FilesCurious LabsPoser 6RuntimePythonlibPhysicsTools.py", line 890, in setupSimulation File "C:Program FilesCurious LabsPoser 6RuntimePythonlibPhysicsTools.py", line 1345, in init File "C:Program FilesCurious LabsPoser 6RuntimePythonlibPhysicsTools.py", line 1618, in _createOdeObjectFromProp File "C:Program FilesCurious LabsPoser 6RuntimePythonlibPhysicsTools.py", line 130, in getPropDimensions AttributeError: 'NoneType' object has no attribute 'WorldVertices This is the full error message I get when I try to run the script. I am using James Casual.
large
It's really odd. I mean.. I GOT that error yesterday, but it was apparently related to either Miki's hair or clothes. I even noticed that "extra" DoF thingie because it flashed red when I hit it with my mouse. But then I loaded a fresh scene and no more problems there... So it's really weird what's going on here :o( I hope face_off can solve it for you quickly!
IM sent to skee to address this problem.
Creator
of OctaneRender
for Poser
Blog
Facebook
Face Off did it he fix my problem. I hope he will put this fix out for everyone. I can now do all those silly little thing that everyone else is doing. This is fun. Face off can now put but on the happy face.... Thanks ...Thanks ....Thanks Can you tell I'm happy. skee
large
I got the program , but I can't get it to do anything. All I get is an error message. Can someone help me thur this. I think I am following the instructions. Poser6..all patches...No brains on my part. skee the lost
NOTE: No trees were killed in the sending of this message, but a large
