Welcome Andrea from Italy ! :) I've been playing with the texture export functions of Carrara lately and found it was crappy . The process is long and buggy . Also, i can't get it to export all channels . If anybody knows the problem, i'm all ears ! Anyway, what i do on my PC is : i save as .obj, enable the "options" checkbox . Then in the options dialog, i check "convert procedural shaders to textures" and choose my texture resolution . Does that work for you ? litst
The export texture function seems to work fine except that the file extensions are not written to the end of your file (at least in MAC OS) so you need to add that yourself. Carrara will write the texture maps according to the mapping mode & faces specified in the shader. Anywhere from 1 to several maps could be drawn. When brought into Bryce or Poser they should apply themesevlves automaticlly. I think that the 3DS format works better for Bryce though. Even grouped objects work well with seperate maps for each part.
I've tried to export in all the supported formats, but the only objects that Carrara creates, are the .XXX (.OBJ, .3DS, etc.) and a file with extension .MTL which size is 1 KB!!!. I've tried to search all over my Hard Disks for file with the name of the exported objects with no extension, but I haven't found non of them. My question is: could this problem be caused by Bryce 4.1 or by Poser 4.3? Infact when I export from this programs in .OBJ format, I always found a .MTL file with the same name of the Object......
Andrea, try to create a new folder and export your file with all the options in that folder . What files do you get there ? .obj and .mtl, i guess ... Also, when you export, Carrara should show an information window at the top of the creen that says something like " exporting shader ..." . Do you have that ? Terri, to rename a shader, select it it the sequencer tray and rename it in the properties tray . You have to be in the assemble room . It's basically the same for all objects and master objects . litst
I've tried to create a new folder, and the result is the same, i found only the .OBJ and the .MTL and no windows appears on the top of the screen. I've tried to unistall Carrara and install it back (with patch too).......nothing to do!!! I've tried to export in all the other formats but Carrara doesn't create the texture file....
Hi everybody, I'm Andrea from italy. I'm trying to learn to use Carrara and I have a problem: I model my objects in Carrara with shaders etc., then I wnato to export them in .OBJ format to re-use them in Bryce 4.1. When I use the export function of Carrara, the dialog asks me the format of the texture, the corrdinates, the path etc, but Carrara DON'T write the .BMP (or .JPG) texture file at all, and when I import the .OBJ file in Bryce it is un-textured. The question is: How can I export the texture of an object and save it in .BMP (.JPG, .TIFF etc) to use it in Bryce. I hope that it's possible, because it seems to me impossible that Carrara had a so great shader editor but it's impossible to export the texture. Thanks for your answers and excuse me for my bad English
