This usually happens when the location for the Python script is wrong or the filename is not correct. I expect yopu are trying to inject the DNA morphs. In this case, when you are working with multiple runtimes or have choosen an other then the standard location, you have to edit the CR2 manually. Check also the Python directory if it's in the main runtime with this location; RuntimePythonposerScriptsDnaFBMaddJessiAllTargetParms.py Filename is only one example call from the Bodymorphs,
Message edited on: 12/02/2005 02:25
Ulli
Hi All, New user here I am trying to use the !jessi body morphs and am getting this error Cant open script for reading (PEPythonEngine::Doscript) Thanks in advance Stan
Jack Of All Trades Master Of None
