Well I guess you learn something every day.. Just as an FYI for me, what type of .mat file would you make in photoshop? I mean, is it going to be 3d, 2d, or 1d. And you would save the image as a .tiff file, right? but if you imported it and you tryed to rotate it or explore the image it would be flat, right ? Thanks for the info guys... -Chris
Well it depends on the type of texture, but generally I use 3d. Tiff has better quality than jpeg because it doesn't loose quality, so that'd be the better choice....but you can use Jpeg too. Yes It would be on a 2d picture frame if you imported it. But notice if you apply it as a object texture, it conforms to the object (Say a primative), Then, you could save it to your library. Regards, Matt
I was just wondering what makes the file format .mat I want to make my own and I am just wondering if I can create something in say Photoshop, save it and then convert it to .mat. Is there a program, or file extention changer or is it not possible. Thanks for any help.
