Mon, Nov 25, 8:44 PM CST
Subject: Ground Plane Texture in P6
peter600101 ( ) posted Sat, 03 December 2005 at 9:19 PM ยท edited Mon, 25 November 2024 at 8:43 PM
This may sound like a silly question, but how do you make ground plane visible in a P6 render. If I go to material room and select the texture image source, I cannot see it in the pose window, or the render itself. Even when I go with the default texture for ground, it is still not visible. P5 works fine; I am obviously missing to do something in P6.
jt411 ( ) posted Sat, 03 December 2005 at 9:35 PM
In the material room, is the ground prop checked as a shadow catcher?
peter600101 ( ) posted Sat, 03 December 2005 at 9:56 PM
Yes, by default the "Shadow_Catch_Only" is checked. I cleared this box and didn't see any change.
linkdink ( ) posted Sun, 04 December 2005 at 1:27 AM
Make sure Display/Guides/Ground Plane is checked (my apologies if this is too obvious a tip).
Gallery
peter600101 ( ) posted Sun, 04 December 2005 at 1:53 AM
I've got it! "Shadow_Catch_Only" box needs to be unchecked, but I also had to link "Diffuse_Color" and "Specular_Color" to the "Color_Texture" window.
