Wed, Jan 8, 6:21 PM CST
Subject: Do I have the correct file for Judy? Wardrobe Wizard not working.
operaguy ( ) posted Sun, 04 December 2005 at 7:08 PM · edited Wed, 08 January 2025 at 6:12 PM
Wardrobe Wizard..... Having trouble converting clothing, any clothing, to Judy. WW working fine otherwise, Jessie --> V3, V3 --> Jessi, etc. 1) is anyone out there using WW to convert to judy, and is it working for you? 2) is this the correct geometry for judy?: P5NudeWoman.obj size: 3705 KB Modified: 8/12/2002 7:47? Error I get is: -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-= Error! Traceback (most recent call last): File "F:Poser 6RuntimePythonPoserScriptsPhilCWardrobe Wizardww.py", line 2293, in ChooseMenuItem File "", line 1, in ? File "F:Poser 6RuntimePythonPoserScriptsPhilCWardrobe Wizardww.py", line 491, in ConvertTo IndexError: list index out of range 'list index out of range' -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-= Thanks for anyone who can help, ::::: Opera :::::
Acadia ( ) posted Sun, 04 December 2005 at 7:16 PM
I was going to try a from Judy to V3, but I can't decode the file I need. I'm checking my CD's and my desktop to see if I happen to have lucked out and saved the Objaction Mover somewhere else.
PhilC ( ) posted Sun, 04 December 2005 at 8:48 PM
Yes could you please post your OBJ statistics. I have a sneaky feeling that there is more than one version of the Judy file.
  • File Name = P5NudeWoman.obj
  • Size = 3.61 MB
  • Modified = Monday, August 12 2002 5:47:28 PM
  • vertices = 24407
  • textures = 24863
  • normals = 24407
  • facets = 24387
  • groups = 76
  • materials = 17
You can read these statistics in UVMapper or any 3D modeling application.
Thanks,
Acadia ( ) posted Sun, 04 December 2005 at 9:02 PM
I have used "Judy Nude" for my "Convert from", and have had no problems using Wardrobe Wizard. Opera, which Judy are you trying to use (hair, hires, nude)?
operaguy ( ) posted Sun, 04 December 2005 at 9:32 PM
Acadia, "Judy Nude" But Acadia, my problem is the other way around, converting TO judy. It is failing as I convert to. I am converting from Jessi clothes and V3 clothes, etc. to judy. Phil: Per UVMapper vertices = 24407 24407 textures = 24863 26473 *** normals = 24407 24407 facets = 24387 24387 groups = 76 76 materials = 17 17 only textures is different ::::: Opera :::::
Acadia ( ) posted Sun, 04 December 2005 at 9:39 PM
I'll try a from V3 to Judy Nude and see what happens. I'll post back.
PhilC ( ) posted Sun, 04 December 2005 at 9:41 PM
Thanks, I'll double check that in the morning. ... Just thought are you converting with genitalia turned on or off?
operaguy ( ) posted Sun, 04 December 2005 at 9:56 PM
thanks acadia, that would help a lot. This might just be me, or maybe not. checking that other delicate item next. og
operaguy ( ) posted Sun, 04 December 2005 at 10:18 PM
WHOA! Stop the presses. THAT WAS IT! I turned off genitalia and just converted a Jessie business suit and a complex V3 batlab flowing garment to Judy with no error. Thank goodness! Judy was getting cold. ::::: Opera :::::
Acadia ( ) posted Sun, 04 December 2005 at 10:23 PM
Ok, I did an outfit from V3 to Judy Nude, and I got the same error as you have: -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-= Error! Traceback (most recent call last): File "F:Poser 6RuntimePythonPoserScriptsPhilCWardrobe Wizardww.py", line 2293, in ChooseMenuItem File "", line 1, in ? File "F:Poser 6RuntimePythonPoserScriptsPhilCWardrobe Wizardww.py", line 491, in ConvertTo IndexError: list index out of range 'list index out of range
Acadia ( ) posted Sun, 04 December 2005 at 10:26 PM
Don't know what you did to get it to work. I still get the error. How do you "Turn off Genitals" on a figure?
operaguy ( ) posted Sun, 04 December 2005 at 11:09 PM
in P6, under the "FIGURE" menu is a choice "genetalia" which I believe is check on by default. Just uncheck it. og
Acadia ( ) posted Mon, 05 December 2005 at 6:05 AM
And in Poser 5?
Khai ( ) posted Mon, 05 December 2005 at 6:13 AM
same same in 4 and PP as well
TrekkieGrrrl ( ) posted Mon, 05 December 2005 at 6:14 AM
Same place in Poser 5
Acadia ( ) posted Mon, 05 December 2005 at 6:28 AM
Thanks, I'll give it a try when I open Poser later.
