Community Center F.A.Q (Last Updated: 2024 Nov 26 7:01 am)
I like animated bannersif they are done well, flash over gif cause they are smoother. I like static banners as well...but I don't see 98% of the banners here cause my scroll finger is to fast :)
♠Ω Poser eZine
Ωâ™
♠Ω Poser Free Stuff
Ωâ™
♠Ω My Homepage Ωâ™
www.3rddimensiongraphics.net
Â
Don't bother me none.
Renderosity is one of the least flash-heavy commercial sites around. One or two small moving banners on a page isn't a problem.
Now -- if Rendo started to go the way of Yahoo, or if it started to use highly irritating tricks like those annoying "Meet the Mudds" Jeep ads (the ones where the banner suddenly "spits" mud over the page that you are trying to read) -- then I'd be upset.
But one or two little flash ads? Big deal. The ads might even be for something that I want. I've bought a couple of items in the past as the result of an interesting banner -- but only once or twice. That's not my usual method of shopping.
Message edited on: 12/07/2005 12:20
My question is about the way I must take to make my own banners, and make then static or flash.
I daresay you'll reach a larger audience with static banners, as many clients may turn off flash in their browser prefs. OTOH, the target demographic (gullible people who stare at flash banners) may mean more flash translates to more sales. if you have any doubt of the latter, just look at what television advertisers are doing now, in a desperate attempt to bottom-feed on their target demographic.
I would think small flash banners would be ok..nothing annoying like brilliant colors flashing at 90 mph, or moving with your mouse or scroll where one cant get away from it.. Something that is easy on the eyes, maybe a fading banner..something along those lines..otherwise a static banner.
~Jani
Renderosity Community Admin
I block Flash on this site. I've seen too many Flash banners that are too annoying to tolerate. I don't hate Flash, per se, I just hate badly done Flash, and unfortunately, too many people do Flash banners badly so now I block them all. ;-) I suspect I'm not the only one who does this, and I've heard merchants say they get a higher click-through rate on static banners, but I could be wrong on that (my memory's not what it used to be ;-). bonni
"When a man gives his opinion, he's a man. When a woman gives her opinion, she's a bitch." - Bette Davis
The easiest way is to use Firefox's AdBlock extension. You can use wildcards. For example, the banner currently at the top of my screen is: http://market.renderosity.com/photos/AdExcl66692.jpg To block all banner ads at Rosity, add this to Adblock: http://market.renderosity.com/photos/* To block Flash banners: http://market.renderosity.com/photos/.swf To block animated GIF banners: http://market.renderosity.com/photos/.gif There are also several Firefox extensions solely for blocking Flash. I use the Flashblock extension. It replaces Flash animations with a button you can click if you want to see it. It has a "whitelist" option, so you can allow Flash from some sites while blocking it from others. I also use NoScript, which blocks Java and Javascript.
Do you have any problem to see these kind of banners, do you like more static ones...?
adh3d website
