If you import them through Poser (as I believe the free one's are only in Poser format) you should be able to get the textures to load correctly too- I think. It's been a while since I used those particular blocks. If you are importing the OBJ's- then you need to have Vue UN-GROUP the OBJ's and display the individual material assignments- then you have to apply the materials manually.
I downloaded some of those cityblocks for testing.Indeed, they are for Poser so the information about textures and materials is not in the obj-file. Could you try to take them into (free) DAZ Studio? And see what happens? I am not too familiar what DS can read, but i guess that might be a chance.
I downloaded the Dystopia cityblocks from Freestuff on this site. As most here probably know, the textures are in a separate folder in the download. In Vue 5 Esprit, I import a block then save it as a .vob. In Vue, the block.vob is grey, no materials.
How do I get the textures/materials on the Dystopia blocks in Vue? The texture folder consists of 26 different jpgs. The Dystopia blocks import as one object, and am I able to get one material on the block using the color map in the Basic Material editor(say only concrete, but not windows, roof, etc.) Am I correct in saying that because the Dystopia blocks import into Vue as one object, I am only able to apply one material and not any of the other 25? Or is there a work-around? I know this has been covered before, but I just can't get it to work (still in process of learning the program).
TIA
gannon
