The normals are reversed. With P6, you can check "normals forward" and fix it. I don't think there's any way to fix it in P5. I suspect if you reverse the normals with the grouping tool, the top of the wings will then be black.
This is an old model, made for Poser 4. Poser 4 didn't care about reversed normals. A lot of old models have this problem, unfortunately.
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=771883&Start=109&Artist=thefixer&ByArtist=Yes
Hi Randym, come to think of it, probably not! My dragon's usually like me, half asleep [rofl]. I did a couple of flying ones but it was kinda face on! See the link! Done in P5Injustice will be avenged.
Cofiwch Dryweryn.
My visual indexes of Poser
content are at http://www.sharecg.com/pf/rgagnon
Yup, it's definitely reversed normals. For reasons I've never been able to figure out, sometimes reversed normals are that odd, yellowish "parchment" color, and sometimes they are dead black. But you know it's reversed normals when you can't change the color.
If there's a way to fix it in the material room, I'd like to know. Sometimes a little bit of displacement helps, but it doesn't seem to work on the dragon.
Where in P6 do you fix the normals. I brought the image into P6 and can't find what you're talking about. And if this is a problem, why hasn't DAZ fixed it????
Weapons of choice:
Here's a quickie belly shot with "normals forward" ticked. It's the MilDragon 3 green texture. With normals forward unchecked, the wings are black, like in your first image.
Well I didn't even install SR1, so I probably don't have it, that's why I'm downloading SR2 right now. I have pretty much stuck with P5 since P6's lighting system is a mystery to me.
Weapons of choice:
Weapons of choice:
Yes, checking "Normals Forward" will fix Sharkey's wings.
With the wings, you can also reverse the normals with the grouping tool. (For Poser 5, say, which doesn't have the "Normals Forward" option.) Sharkey's wings are inside out, as Poser sees things, so reversing the normals fixes the problem.
You can't do that with the dragon wings, because you're looking at both sides of one surface. If you reverse the normals, the top of the wings will be wrong.
Weapons of choice:
