A few things to note about particles and collision objects: -Increase the poly count of collision objects if having problems with collisons. Objects that have low poly counts can sometimes not have enough of a surface for good accurate collisions. The result is pass through. -Watch what mass setting you use as boosting it up too high will push the particles through collision objects.
I'm having trouble with particles in metaball form going down a pipe. It breaks out of the object - even though I have all objects set to collide. Any ideas? I have to render again... too big. But it is dropping out the bottom of the pipe on a 45 degree slant.
Never Give Up!
