Tue, Feb 4, 5:02 PM CST
Subject: Saving Trans and textures
Butch ( ) posted Wed, 14 March 2001 at 9:26 AM ยท edited Tue, 04 February 2025 at 4:54 PM
Is there a way to save the transmaps and textures in the libraries? I was just checking through my texture folder and I so many that I didn't know that I had. I would like to be able to see them on the article of clothing in the library instead of the ghost outline that I get when I try to save them. thanks Buch
Hdrider ( ) posted Wed, 14 March 2001 at 10:32 AM
Hello, Well, there are two ways of doing it. 1) If you have the Pro Pack, just render it to a 91x91 png file and save it to the same filename. Note: If you have a background loaded, it won't save it directly. Work Around: Load the square prop and resize it to fit the screen. Apply your background texture and then do #1 2) Render it to a 91x91 pct file and use the RSR Converter program found here in the freestuff Poser/Utilities section. Note: The pct may have to be run through a paint program to work correctly. Hope this helps some. Later...
No good deed goes unpunished ...
bloodsong ( ) posted Wed, 14 March 2001 at 12:16 PM
naw man; render the item as you want the thumbnail to appear, then paste the image to the background. yank the camera away so it isn't pointing at the item any more, and all you see is the rendered background. with the item selected, add it back into the library.
Butch ( ) posted Wed, 14 March 2001 at 12:38 PM
Bloodsong, you can cut and paste in Poser??? Could supply alittle more detail?? I didn't know that you could do that. Just goes to show that you teach an old dog new tricks, or that you learn something everyday. thanks
Hdrider ( ) posted Wed, 14 March 2001 at 2:43 PM
bloodsong, If you have the Pro Pack, I don't think that method will work. Or so I've heard. I haven't tried it personally. Later...
ScottA ( ) posted Wed, 14 March 2001 at 4:45 PM
Hdrider is correct. This method won't work with the propack. But for Butch. Here are the steps to do what Bloodsong suggested: 1.)open the figure. 2.)render a picture (this will be your thumnail picture). 3.)go to display ->and select "Paste onto Background" 4.)select the camera and move it with the X translate dial. 5.)add the figure to your library ScottA
bloodsong ( ) posted Thu, 15 March 2001 at 11:55 AM
well.... not everybody has the pro-pack, you know. :) but you're right, it won't work with THAT.
