Hello, Well, there are two ways of doing it. 1) If you have the Pro Pack, just render it to a 91x91 png file and save it to the same filename. Note: If you have a background loaded, it won't save it directly. Work Around: Load the square prop and resize it to fit the screen. Apply your background texture and then do #1 2) Render it to a 91x91 pct file and use the RSR Converter program found here in the freestuff Poser/Utilities section. Note: The pct may have to be run through a paint program to work correctly. Hope this helps some. Later...
No good deed goes unpunished ...
Hdrider is correct. This method won't work with the propack. But for Butch. Here are the steps to do what Bloodsong suggested: 1.)open the figure. 2.)render a picture (this will be your thumnail picture). 3.)go to display ->and select "Paste onto Background" 4.)select the camera and move it with the X translate dial. 5.)add the figure to your library ScottA
Is there a way to save the transmaps and textures in the libraries? I was just checking through my texture folder and I so many that I didn't know that I had. I would like to be able to see them on the article of clothing in the library instead of the ghost outline that I get when I try to save them. thanks Buch
