I use it, Tech Support is good. It needs you to get into the guts of your database to do the occasional manual tweaking (such as when the databases get corrupted), but ask the software author and he'll sort you out !
I use it for Poser Artist (= P4) and now P6. It helped me find the references (which PDOExplorer will also do), but it can also tell you if you've got files (such as texture files) which are no longer used by any of your poser-type files, and you can remove those, save hard disk space.
I find it useful.
Eternal Hobbyist
I bought the program and it has been a harrowing experience for me so far. I've had to reinstall a contents because they wouldn't load anymore and I had a very hairy time with some of the Poser 6 stuff. dfI have 3 runtimes and it's a bit confusing and I hope I don't end up having to reinstall everything all over again.
I've seen CR Pro II advertised and want to know what experience anyones had with it. I've had some problems with Poser and D/S now being able to find file references. Is this safe to use with my Poser 6 and 4 Pro Pack applications? I understand this program will help my runtime run better. Any feedback?
