Fri, Jan 10, 11:48 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 9:07 am)
Subject: Poser 6 Out of Memory?
Angelouscuitry ( ) posted Tue, 20 December 2005 at 12:49 AM ยท edited Fri, 10 January 2025 at 11:46 AM
i thought this was a Poser 4 issue. I've been working on a scene for an hour, and now it wo'nt let me save my progress?
Dizzi ( ) posted Tue, 20 December 2005 at 2:39 AM
Do you have the latest Service Release (SR2) installed? That sounds like a pre SR1 error.
DigitalDreamer ( ) posted Tue, 20 December 2005 at 4:30 AM
and very much a post SR2 error so be careful. I installed SR2 and had no problems with it until I had a complex pic then ran out of memory on a 1.5 gig machine! It did the same with dynamic clothing and with rendering a pic with texture filtering on. Memory problems are still a huge Poser issue and will continue to be, I suspect, until/unless they rewrite the core program.
Dizzi ( ) posted Tue, 20 December 2005 at 5:38 AM
Running out of memory while rendering has nothing to do with the saving bug...
nightsong ( ) posted Tue, 20 December 2005 at 10:14 AM
The inability to save due to out of memory errors is definitely something that goes away after installing the first service pack. Watch out -- if you were trying to save over an old file, the old file could be toast now too. The SR1 fix is awesome. I am having a lot more troubles of other kinds after installing the second service pack, though, so be careful.
DigitalDreamer ( ) posted Tue, 20 December 2005 at 2:44 PM
nightsong - I agree that SR1 is awesome; I'm not convinced about SR2. I've found another error - it won't open files saved under SR1. Dizzi - I know the faults are unrelated - just giving Angelous a further example of memory related probs in SR2. I too have experienced the saving bug.
Foo-Dog ( ) posted Tue, 20 December 2005 at 2:53 PM
Does/did Poser have a 'Memory Leak'?
Angelouscuitry ( ) posted Tue, 20 December 2005 at 4:57 PM
I found that turning off Edit > Preferances > Misc > External Binaries worked like a charm. I havn't had any problems saving since then! I hav'nt installed any updates yet, but thank you all for the SR1-SR2 comparison! = )
Phlegethon ( ) posted Sun, 25 December 2005 at 4:25 PM
@DareWolf No, Poser doesn't have a memory leak but it really uses the available memory as inefficient as possible. Terminating the rendering engine frees all memory. I hope they fix this in SR3 or Poser 7 since it's been a problem in Poser 5 also.
