Sun, Feb 16, 10:53 PM CST
Renderosity Forums / Animation
Welcome to the Animation Forum
Animation F.A.Q (Last Updated: 2025 Feb 09 6:34 am)
In here we will dicuss everything that moves.
Characters, motion graphics, props, particles... everything that moves!
Enjoy , create and share :)
Remember to check the FAQ for useful information and resources.
Animation learning and resources:
[Animations]
Subject: Anime techniques
madriver ( ) posted Mon, 19 December 2005 at 2:38 PM ยท edited Tue, 26 November 2024 at 3:42 PM
Anyone have any ideas about how to create that "trembling" effect seen in many anime movies? I'm thinking it's a simple 2 frame cycle, but how different and which parameters change within those 2 frames?
nemirc ( ) posted Mon, 19 December 2005 at 3:48 PM
and what is it that should be trembling?
nemirc
Renderosity Magazine Staff Writer
https://renderositymagazine.com/users/nemirc
https://about.me/aris3d/
madriver ( ) posted Mon, 19 December 2005 at 4:04 PM
A person/character. That shaking effect when someone is nervous or anxious, for instance...
nemirc ( ) posted Mon, 19 December 2005 at 4:08 PM
That is keyframe-animation ;) You can try animating the twist values at a high frequency and see the result.
nemirc
madriver ( ) posted Mon, 19 December 2005 at 4:10 PM
I will probably do it in Photoshop instead of in Poser but will try it in 3D as well.
Bobasaur ( ) posted Tue, 20 December 2005 at 9:22 AM
Why Photoshop? If you had a compositing program like After Effects you could render the character seperate from the background and animate the position manually to give you the jiggles. Actually Premiere, Final Cut Pro and other non-linear editing software can do it as well. In Poser I'd probably try animating the body or the hips. I'd set keyframes where the tremble began and ended to make sure I kept my character in the right place, then open up the graph editor and just move the desired attribute (up and down somewhat randomely along the graph between the beginning and ending points. It would be pretty quick and painless that way.
madriver ( ) posted Tue, 20 December 2005 at 11:40 AM
Thanks bobasaur.
Miss Nancy ( ) posted Tue, 20 December 2005 at 7:57 PM
they sometimes do it in a face close-up, by switching the eye highlight slightly back-and-forth.
