Thu, Nov 28, 6:40 PM CST
Subject: Cloth Room Question
Fugazi1968 ( ) posted Mon, 26 December 2005 at 10:54 AM ยท edited Sun, 27 October 2024 at 4:21 AM
Quick question :) which I suspect has an even quicker answer. can you get a cloth simulation to drape at the last frame, without exporting the cloth and reimporting and starting a new simulation? Thanks John :)
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
JamieReid ( ) posted Tue, 27 December 2005 at 12:50 AM
I'm not quite sure what you mean, but after all the posing is done you could just add a frame (or more) then set the "end frame" simulation setting to match. The cloth will continue to drape while the object remains in it's last position.
Fugazi1968 ( ) posted Tue, 27 December 2005 at 1:53 AM
Unfortunately that doesnt work :( once the sim has started the mesh only reacts to collisions, so when you add frames to the end the cloth doesnt do anything. John
nruddock ( ) posted Tue, 27 December 2005 at 7:18 AM
You also need to change which frames the simulation calculates for. The default is just frames 1 through 30.
