Wed, Feb 5, 1:15 PM CST
Subject: Bryce objects to Poser?
gordongriggs ( ) posted Thu, 15 March 2001 at 11:47 PM ยท edited Wed, 05 February 2025 at 4:45 AM
Hi, I am new to Poser and Bryce. I was wondering if there is anyway to create an object in bryce and then import it to use in Poser. I am using Poser 4 and Bryce 4. thanks!
morganza ( ) posted Thu, 15 March 2001 at 11:56 PM
I'm fairly new to this to but i think if you export a model in Bryce as an object, then you can import it into poser and vice versa. I hope i'm right, Morgan
carteron ( ) posted Fri, 16 March 2001 at 6:37 AM
Too bad, but Poser dont know Bryce formats.No way. Too bad, Bryce can only export terrains or groups of terrains as wavefront.obj for Poser Beeing french, i have a french version, but i think it is also "terrains" in the US one. If you well practice the terrain editor, you will learn than many other thinks than landsapes are possible, as 3d texts, sci-fi towns, an island with your face, etc, etc. Poser to Bryce is more easy. Enjoy
Poppi ( ) posted Fri, 16 March 2001 at 7:00 AM
It is terrains, and lattices. In order to do this, select your object and hit control d. For backgrounds, just render and save as a .jpg or .tiff and put into poser.
RonGC ( ) posted Fri, 16 March 2001 at 10:52 AM
On the PC it's control d. On the Mac hit the key with the apple logo on it plus the d key to export. Nothing made from Bryce primatives is exportable in any format other than Obp. For translating imported objects from a format such as LW or Cob to Obj or 3Ds you have to enter smoothing mode first. select the object hit the E in the object menu that appears to enter smoothing mode then hit the apple and D keys to get an export options menu. This way you can use bryce to translate other models found on the web to poser useable ones. Hope this helps :-)
