Too bad, but Poser dont know Bryce formats.No way. Too bad, Bryce can only export terrains or groups of terrains as wavefront.obj for Poser Beeing french, i have a french version, but i think it is also "terrains" in the US one. If you well practice the terrain editor, you will learn than many other thinks than landsapes are possible, as 3d texts, sci-fi towns, an island with your face, etc, etc. Poser to Bryce is more easy. Enjoy
On the PC it's control d. On the Mac hit the key with the apple logo on it plus the d key to export. Nothing made from Bryce primatives is exportable in any format other than Obp. For translating imported objects from a format such as LW or Cob to Obj or 3Ds you have to enter smoothing mode first. select the object hit the E in the object menu that appears to enter smoothing mode then hit the apple and D keys to get an export options menu. This way you can use bryce to translate other models found on the web to poser useable ones. Hope this helps :-)
Hi, I am new to Poser and Bryce. I was wondering if there is anyway to create an object in bryce and then import it to use in Poser. I am using Poser 4 and Bryce 4. thanks!
