Tue, Feb 4, 11:59 AM CST
Subject: looking for a motorcycle, i am
mizombie ( ) posted Wed, 11 December 2002 at 3:49 AM · edited Tue, 04 February 2025 at 11:58 AM
LOl, well sort of. I am in need of a crotch rocket/ bullet bike what have you (pending on where your from) something reasonably cheap for Poser. I have looked but all i seem to find are the old customs and not so hot speed bikes. prefer a Ducati or newer BMW bike if possible.
Erlik ( ) posted Wed, 11 December 2002 at 4:03 AM
I downloaded a Harley from somewhere... ummmm: http://www.animationpitstop.com/models/users/vehicles.shtml http://www.stmuc.com/moray/mevehicle.html http://laap.uncg.edu/developers/public_download/3dobjects/ http://www.3dworldclub.com/preview.aspx?ModelCode=2489 No Harley as such, though. The last one costs $49 to register on the site, which has lots of models.
-- erlik
SAMS3D ( ) posted Wed, 11 December 2002 at 4:18 AM
You should definately check out DAZ3D, they have a great hog there. Sharen
SAMS3D ( ) posted Wed, 11 December 2002 at 4:21 AM
This is there harley....just a beauty...Sharen
Attached Link: http://store.daz3d.com/catalog/product.php?pidx=369&paridx=2
sorry, here is the link...Sharen
mizombie ( ) posted Wed, 11 December 2002 at 4:30 AM
sorry folks I am looking for a speed bike right now. I have the DAZ Harley and several others. I am looking for something similar to this
mizombie ( ) posted Wed, 11 December 2002 at 4:32 AM
or this
Niles ( ) posted Wed, 11 December 2002 at 4:44 AM
You might try 3dcafe, they have a few , I think this one is a LWO.
SAMS3D ( ) posted Wed, 11 December 2002 at 4:58 AM
Yes, there is one at 3Dcafe, I am just too slow on these posts....LOL
TygerCub ( ) posted Wed, 11 December 2002 at 5:10 AM
Do a search for "MOTO" in the free section. I was looking for one earlier this year and that's where folks pointed me. You should find 4 that might fit your needs.
Mazak ( ) posted Wed, 11 December 2002 at 8:31 AM
Attached Link: http://www.honda.co.jp/hondafan/plamo/
Honda? In dxf and Lightwave format. Mazak
Google+ Bodo Nittel
Little_Dragon ( ) posted Wed, 11 December 2002 at 10:36 AM
I've been to HondaFan's site, and should warn you ... some assembly is required.
the Escapist's Poser Props Collection
La page KALAT
The 3D Studio (in .3ds format by Ricardo Castelo, look under Vehicles)
mizombie ( ) posted Wed, 11 December 2002 at 12:54 PM
thanks guys, I think i have what i need now Mazak, glad you sent me that Honda link. It brings back memories of being 12-13yrs old and tearing the hell out of their indestructable Honda Trail 70 (or on their site DAX )
Mazak ( ) posted Wed, 11 December 2002 at 1:50 PM
bikermouse ( ) posted Wed, 11 December 2002 at 5:24 PM
Sharen, Except that this HD is a block head it looks a lot like my old '77. will it show a Left view ? I was gonn try to make one like this a few months back, but got stuck on the frame. - TJ
raven ( ) posted Wed, 11 December 2002 at 8:45 PM
Here's the Blackbird from the Honda site in Poser.
artdude41 ( ) posted Fri, 13 December 2002 at 7:00 AM
heres the HONDA NR in poser
Pamola ( ) posted Sun, 15 December 2002 at 1:58 PM
Attached Link: http://www.iw43d.com/Poser/Vehicles/Cycles/Cycles.htm
These are all beauties! We have A Harley Softail and HD Chopper as well.
Pamola ( ) posted Sun, 15 December 2002 at 2:09 PM
These are all beauties..... WOW!
We've got a couple of Harley Davidson models also. Here are some images of our Softail and Chopper for you.
Cheers!
Pam
Pam
Pamola ( ) posted Sun, 15 December 2002 at 2:13 PM
Harley Davidson Chopper
Pamola ( ) posted Sun, 15 December 2002 at 2:14 PM
Harley Davidson Softail
WarlockDA13 ( ) posted Mon, 30 December 2002 at 9:27 AM
Any have a poser ready version of the Blackbird and NR from Hondafan up for download anywhere by chance?
AntoniaTiger ( ) posted Thu, 29 December 2005 at 12:37 PM
artdude41, there's an error in the Honda NR model, which I see you haven't corrected. The drive chain is in the wrong place. Don't worry, folks, it's correctable in Poser. Load just the rear_suspention.lwo file (sic), and set the camera up to look at it from the left side. The chain is that funny loop, small at the back and big at the front, which runs out at the back. Use the Materials room and check the name of the material for the chain. It should be "Box19 carbon" Go back to the Pose room and open the grouping tool. Create a new group named "Chain" and use "Add Material" to assign the chain material to the new group. New Group again. This one will be everything else, so we might as well call it "RearSuspension". Start with "Add All" and then use "Remove Group" to remove the "Chain" group. We now create two new props, using the "Create Prop" button. One is created from each group just created, one prop being the chain and the other being the rest of the rear suspension. We can now delete the original "rear_suspention". It whould be the first of three props listed. You won't see any apparent difference in the preview window, but now there will be two props in the list. Now import the rear_brake.lwo which includes the chain sprocket, so you can see where you want the chain to be, and select the chain prop. Set y-rotate to 180 Set x-rotate to -3 The next two value will be different if you've re-scaled things, but it's easy to fit the chain to the toothed wheel. Set y-trans to 0.438 Set z-trans to 27.662 I'm not sure that the end result has the chain running to exactly the right place, but it's close to what I've found in photos. Now delete the rear_brake prop. Export the rear suspension and chain props to a new .obj and you can load that instead of the original .lwo file. Or a .lwo, as long as you don't overwrite the original. It's not hard to make a Poser prop, just tedious. You import all the .lwo files (it's a huge model in Poser), export the whole assembly as a .obj, and then import that .obj at about 125% of figure size, centred, and dropped to the ground. That's close for scale, maybe a little large. Then save to the Props library. I'll let somebody else explain how to rig ir as a figure. I don't think the seat was designed for people with tails. :)
AntoniaTiger ( ) posted Thu, 29 December 2005 at 1:02 PM
And here's a picture showing the corrected chain location. I've changed the colour so that it stands out well.
