Sat, Nov 2, 2:40 PM CDT
Forum Moderators: wheatpenny, Deenamic Forum Coordinators: Anim8dtoon
Photography F.A.Q (Last Updated: 2024 Nov 01 10:53 pm)
Subject: Depth of Field Preview Button
coolj001 ( ) posted Wed, 04 January 2006 at 11:15 PM · edited Sat, 26 October 2024 at 3:19 PM
Do you ever use this? When the button is depressed this function sets the lens aperature to the setting used in the camera's current exposure settings so you can see the actual depth of field in the viewfinder. Whenever I try this everything just looks darker; I don't notice any difference in the depth of field. It looks like I can see the depth of field w/o using the button. I think I am missing something.
coolj001 ( ) posted Wed, 04 January 2006 at 11:26 PM
After re-reading my manual I just noticed it says the button enables you to see the "effect" of the depth of field in the viewfinder. This may be different than "actual" depth of field?
Tedz ( ) posted Thu, 05 January 2006 at 12:21 AM
Not a clue...i am just a comic...insane grin
coolj001 ( ) posted Thu, 05 January 2006 at 1:05 AM
Thanks Tedz. I feel better now :-)
FuzzyShadows ( ) posted Thu, 05 January 2006 at 1:13 AM
I'm with you on this one coolj. I think maybe my eyes aren't good enough to see the difference. But yes, you're supposed to be able to see the depth of field just as it will come out in your picture.
cbender ( ) posted Thu, 05 January 2006 at 1:35 AM
hmmm... on my DSLR i can do it and it works... if i press that button the aperture closes and i see a difference... (well - i don't see anything if i have the aperture fully open...) what cam do you use?
Margana ( ) posted Thu, 05 January 2006 at 1:47 AM
I didn't know there WAS a DOF preview button.But then I just got this cam and know very little about it. I'm always learning something new here!
Marlene <")
Marlene S. Piskin Photography
My Blog
"A new study shows that licking the sweat off a frog can cure depression. The down side is, the minute you stop licking, the frog gets depressed again." - Jay Leno
coolj001 ( ) posted Thu, 05 January 2006 at 1:49 AM
I am using a Konica Minota 5D and one of their D-series lens designed for use with this camera. I wonder if my lens automatically does this DOF preview thing for me. Maybe if I tried a third party or non-D series lens it would work differently? hmmmm.
coolj001 ( ) posted Thu, 05 January 2006 at 1:50 AM
Margana...not all cameras have such a button.
Margana ( ) posted Thu, 05 January 2006 at 1:55 AM
Ah.That would explain it.Thank you!!! ;^) Hope it works out for you...it sounds like an interesting feature.
Marlene <")
My Blog
cbender ( ) posted Thu, 05 January 2006 at 2:09 AM
have you tried to close the shutter all way (in aperture mode) and tried the button there...?!? should work :) normally you should also see the viewfinder-pic getting darker a bit
coolj001 ( ) posted Thu, 05 January 2006 at 2:55 AM
I think I have found the problem...me! lol. I just tried again and I think I actually noticed a difference in the DOF. It definetely gets darker, and the difference in DOF is slight but apparant. The stuff outside the focus area becomes a bit clearer when using the button. The amount of change depends on the aperature as it should. It is just hard to tell when it gets darker. I must start paying better attention! I believe it was working correctly the entire time but I wasn't. :-)
cbender ( ) posted Thu, 05 January 2006 at 3:17 AM
lol but well... :) that does happen sometimes... :D try it in good light and with the aperture closed as far as possible (f=22) and you'll see big difference... :))
coolj001 ( ) posted Thu, 05 January 2006 at 3:28 AM
Thanks for getting me to try it again...I may not have ever realized it works if you didn't leave that last comment. Yes...I must try this outdoors...during the day. :-)
jcv2 ( ) posted Thu, 05 January 2006 at 4:00 AM
Yep, it makes things darker, and the effect is least noticable when using telelens (DOF is relatively shallow), but using wide angle you can notice it very well!
TwoPynts ( ) posted Thu, 05 January 2006 at 4:53 AM
When I get a cam with that feature, I'll let you know. I don't know if my eye would be good enough to see much of a difference though. Come to think of it, I seem to recall my old TopCon film camera had such a button, it did make everything darker. I never really used it though.
tvernuccio ( ) posted Thu, 05 January 2006 at 11:12 AM
sorry...i don't anything about this kind of button. :(
Nameless_Wildness ( ) posted Thu, 05 January 2006 at 3:52 PM
DOF preview is mainly on SLR's,...DSLRS
Margana ( ) posted Thu, 05 January 2006 at 3:58 PM
Is it on the 20D do you think?Because I just got it two minutes ago...
Marlene <")
My Blog
Nameless_Wildness ( ) posted Thu, 05 January 2006 at 4:01 PM
yes, it will Marlene...on the body!....most DSLR Canons have this feature...not sure about other makes of DLSR.
Margana ( ) posted Thu, 05 January 2006 at 5:13 PM
Oh goody!!!!Now I can keep reading this thread and it will be relevant,lol!
Marlene <")
My Blog
TomDart ( ) posted Thu, 05 January 2006 at 9:08 PM
With digital cams, well, many of them that even have a dof button, you set the aperture and hit the button, get a look. What was nice with some old film slrs is you could move the lens apeture and see the effect immediately, one stop to another. I did this at work today with a coworkers Minolta 35mm slr. I have not tried this with digital lenses that actually have aperture settings, using manual. I do not know if it will work. Many cpu digital lenses have no apetrure setting, using camera for that. Otherwise, you are advised to set the lens at max aperture and lock it there. Then the cam does the stuff. I do have a lens or two with manual aperture and will try to see if I can cycle through using the lens on manual and get a dof preview...I doubt it will work since the cam is wanting to do it's own stuff. But, we will see. With a film camera, the preview is very useful in macro and closeup shots. It is realtively easy to see the central area of focus and adjust as needed, to focus in a third or whatever. Well, you do need decent light and a good eye while doing it..at least I do. For macro, I see the feature very helpful even if I have neglected this feature.
UKmac ( ) posted Fri, 06 January 2006 at 12:19 AM
I use it nearly all the time (Canon 10D), I find it very useful. I find it works beter on bright sunny days, as my Cyprus series. Steve
PeeWee05 ( ) posted Fri, 06 January 2006 at 2:01 AM
My camera's cheap!!! I don't have one of those!!!
Rights Come With Responsibilities VAMP'hotography Website VAMP'hotography Blog
