Forum Moderators: wheatpenny, Deenamic Forum Coordinators: Anim8dtoon
Photography F.A.Q (Last Updated: 2024 Nov 01 10:53 pm)
I didn't know there WAS a DOF preview button.But then I just got this cam and know very little about it. I'm always learning something new here!
Marlene <")
Marlene S. Piskin Photography
My Blog
"A new study shows that licking the sweat off a frog can cure
depression. The down side is, the minute you stop licking, the frog
gets depressed again." - Jay Leno
Ah.That would explain it.Thank you!!! ;^) Hope it works out for you...it sounds like an interesting feature.
Marlene <")
My Blog
I think I have found the problem...me! lol. I just tried again and I think I actually noticed a difference in the DOF. It definetely gets darker, and the difference in DOF is slight but apparant. The stuff outside the focus area becomes a bit clearer when using the button. The amount of change depends on the aperature as it should. It is just hard to tell when it gets darker. I must start paying better attention! I believe it was working correctly the entire time but I wasn't. :-)
When I get a cam with that feature, I'll let you know. I don't know if my eye would be good enough to see much of a difference though. Come to think of it, I seem to recall my old TopCon film camera had such a button, it did make everything darker. I never really used it though.
Is it on the 20D do you think?Because I just got it two minutes ago...
Marlene <")
My Blog
Oh goody!!!!Now I can keep reading this thread and it will be relevant,lol!
Marlene <")
My Blog
With digital cams, well, many of them that even have a dof button, you set the aperture and hit the button, get a look. What was nice with some old film slrs is you could move the lens apeture and see the effect immediately, one stop to another. I did this at work today with a coworkers Minolta 35mm slr. I have not tried this with digital lenses that actually have aperture settings, using manual. I do not know if it will work. Many cpu digital lenses have no apetrure setting, using camera for that. Otherwise, you are advised to set the lens at max aperture and lock it there. Then the cam does the stuff. I do have a lens or two with manual aperture and will try to see if I can cycle through using the lens on manual and get a dof preview...I doubt it will work since the cam is wanting to do it's own stuff. But, we will see. With a film camera, the preview is very useful in macro and closeup shots. It is realtively easy to see the central area of focus and adjust as needed, to focus in a third or whatever. Well, you do need decent light and a good eye while doing it..at least I do. For macro, I see the feature very helpful even if I have neglected this feature.
My camera's cheap!!! I don't have one of those!!!
Rights Come With Responsibilities VAMP'hotography Website VAMP'hotography Blog
Do you ever use this? When the button is depressed this function sets the lens aperature to the setting used in the camera's current exposure settings so you can see the actual depth of field in the viewfinder. Whenever I try this everything just looks darker; I don't notice any difference in the depth of field. It looks like I can see the depth of field w/o using the button. I think I am missing something.
