Carrara F.A.Q (Last Updated: 2025 Jan 11 8:46 pm)
Smooth it before importing it. That is, if it can be smoothed without destroying it.
Looks like possibly some bad polys there. What I'd do, is jump into the vertex room and see if Carrara has set creasing for any edges. You want creasing, but only for the blade edge and back itself (if the poly count is high enough you won't even need that). To really get it glassy, crease just what you need then apply a level or two of SubD smoothing.
First question. :) The cutting board is an imported .obj. In the bottom right corner, the curve isn't totally smooth. Is there a way to further smooth it inside Carrara, or do I need to make sure it's perfectly round before importing it?
Second question...any suggestions? :)
~ Nevanna ~
nevanna.blogspot.com
