Tue, Dec 24, 8:25 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: n00b question -- smoothing?
Nevanna ( ) posted Wed, 04 January 2006 at 10:15 PM · edited Tue, 24 December 2024 at 7:11 AM
I've been playing with the Carrara 5 demo...pretty cool so far, I think I really like it.
First question. :) The cutting board is an imported .obj. In the bottom right corner, the curve isn't totally smooth. Is there a way to further smooth it inside Carrara, or do I need to make sure it's perfectly round before importing it?
Second question...any suggestions? :)
~ Nevanna ~
nevanna.blogspot.com
falconperigot ( ) posted Thu, 05 January 2006 at 4:06 AM
First question: you can smooth an OBJ by either subdividing or applying smoothing in the modeling room. That should make it look a bit better. Second question: Add some meat? :) The shader on your board looks like stone. You might want to experiment with some of the wood presets.
ominousplay ( ) posted Thu, 05 January 2006 at 10:45 AM
I'd like to see a bolt / nut in the handle to hold the hilt of the knife in place. I'm also a fan of the chef knives, you know the ones... thicker blade - It would stand out more in the scene. R
Never Give Up!
ShawnDriscoll ( ) posted Thu, 05 January 2006 at 10:54 AM
Smooth it before importing it. That is, if it can be smoothed without destroying it.
nomuse ( ) posted Sat, 07 January 2006 at 2:36 AM
Looks like possibly some bad polys there. What I'd do, is jump into the vertex room and see if Carrara has set creasing for any edges. You want creasing, but only for the blade edge and back itself (if the poly count is high enough you won't even need that). To really get it glassy, crease just what you need then apply a level or two of SubD smoothing.
