Sun, Feb 9, 11:56 AM CST
Renderosity Forums / Animation
Welcome to the Animation Forum
Animation F.A.Q (Last Updated: 2025 Feb 09 6:34 am)
In here we will dicuss everything that moves.
Characters, motion graphics, props, particles... everything that moves!
Enjoy , create and share :)
Remember to check the FAQ for useful information and resources.
Animation learning and resources:
[Animations]
Subject: Blend node for complete figure ...is it possible?
beos53 ( ) posted Thu, 05 January 2006 at 7:10 AM · edited Mon, 03 February 2025 at 10:39 PM
Attached Link: http://webpages.charter.net/swieg123456/alldivx1.avi
I have been working on this since nruddock and svdl pointed me in the right direction. It is a pain in the ... to create and I still have a lot work to on it and to learn. This is what I did using the Blend node The only problem I had was the blend node on the Aiko figure, I set it up for the Torso and then applied it to the complete figure. Only the Torso worked, I had to go in and set the blend nodes for each part of the figure. I tried it several times, but still the same thing. Is there a way to set up the animation for the node for all parts of the figure? I hope I made myself clear Everything was done in Poser in 120 frames. It is about 256K and in DivX 6
PoserPro 2014, Windows 7, AMD FX-6300 6 core, 8 GB ram, Nvidia GeForce GTX 750 Ti
Bobasaur ( ) posted Thu, 05 January 2006 at 9:44 AM
I have no idea (I still use PPP). However, it looks very cool. when you get it figured out please post it so we can see the finished result.
justpatrick ( ) posted Thu, 05 January 2006 at 8:09 PM
I don't know if it's possible either, but what you have done there sure does look cool!
beos53 ( ) posted Fri, 06 January 2006 at 11:39 PM
Thank you for your comments. As far as I can tell and from what I have found out the animation settings don't carry over to the complete figure when copied from one part the applied to all.
