Mon, Nov 25, 9:05 AM CST
Vue F.A.Q (Last Updated: 2024 Nov 21 4:12 am)
Subject: Export objects from lightwave for use in v5i
Flak ( ) posted Thu, 05 January 2006 at 8:01 PM · edited Fri, 22 November 2024 at 4:15 AM
Has anyone had this effect with an .obj object (exported from LW 8.3) when importing and viewing it as a wireframe in V5i (with the 5.09 beta patch installed) - i.e the wireframe is all over the place (though it renders fine, as you can see in the preview image, its just a mongrel to deal with when positioning things relative to it). I've had this happen with a fair few obj's exported from Lightwave, but it doesn't do it with .lwo files.
Digital WasteLanD
Flak ( ) posted Thu, 05 January 2006 at 8:04 PM · edited Thu, 05 January 2006 at 8:08 PM
In the official 5.08 patch, that same object with the same import settings looks like this above, so I don't *think* its something I'm botching up in the export/import side of it (but you never know).
This is how the wireframe looks in bryce, LW, uvmapper, ...
Also, does Vue5infinite tend to hang when you try and import too big a .lwo file into it (like over 60000 polys or thereabouts)??
Thanks for any ideas/help.
edit - I've gone back and uninstalled/reinstalled V5i to get from the 5.09 to the 5.08 after reading how the rollback can be problematic.
Message edited on: 01/05/2006 20:08
Digital WasteLanD
Djeser ( ) posted Fri, 06 January 2006 at 4:32 AM
You might want to put in a tech support ticket over at e-on and include the images you posted above so they can see what the issue in 5.09 is and get it addressed.
Sgiathalaich
Flak ( ) posted Fri, 06 January 2006 at 7:25 AM · edited Fri, 06 January 2006 at 7:25 AM
Yeah, probably will do another ticket. I posted here wondering if anyone else had seen this - or whether it was me doing something strange that someone else may have done and sorted out themselves (surely I thought others would have imported from LW to Vue via the .obj format). Thanks anyway :)
Message edited on: 01/06/2006 07:25
Digital WasteLanD
Gareee ( ) posted Sat, 07 January 2006 at 9:00 AM
mark over in the cgtalk forums has been working on a tutorial for getting lightwave content into vue properly.. might wabnt to check his threads over in the cgtalk vue forum...
