Sat, Jan 11, 9:48 AM CST
Subject: How can I combine two hairs?
julil ( ) posted Fri, 06 January 2006 at 5:28 PM · edited Sat, 10 August 2024 at 8:15 AM
This may be a bizarre question, but I'm wanting to combine two hairs, the history hair (set to base only) and Darkworld's Mistress Hair. But when I go to add one, the first one deletes. Is there a way to use them both on the same V3? TIA, Juli
richardson ( ) posted Fri, 06 January 2006 at 5:31 PM
Load the hair without a figure. Load 2nd hair and parent it to the 1st. Then save 1st hair back to hair library with both selected. You can lock the hair before you save, too.
julil ( ) posted Fri, 06 January 2006 at 5:34 PM
Thank you...I'll try this now! You guys are all great.
julil ( ) posted Fri, 06 January 2006 at 5:50 PM
Hmm, this didn't work. For some reason the parent is greyed out when I have the hair only loaded. I went ahead and saved both hairs, and the preview pic looked right, but when I went to load, it only loaded one.
julil ( ) posted Fri, 06 January 2006 at 6:12 PM
Okay, I putzed around with it, and it needs work, but I think I've got it. Thank you!
EnglishBob ( ) posted Fri, 06 January 2006 at 7:48 PM · edited Fri, 06 January 2006 at 7:48 PM
Save one of the hairs into the Props library, rather than the hair library. Accept when it asks if you want it to be a smart prop. That prop hair can then be added to anything; it's only stuff from the hair library which removes any existing hair from the figure.
Message edited on: 01/06/2006 19:48
richardson ( ) posted Fri, 06 January 2006 at 8:42 PM
Ahh!... Thanks EBob.
julil ( ) posted Sat, 07 January 2006 at 12:08 AM
Yes, thanks EnglishBob! I was able to get the hairs on her head and looking the way I wanted, but no matter how I did the parenting, locking and unlocking, the hair stayed in the air and I was going to have to manually move the hair when I posed her. Juli
PabloS ( ) posted Sat, 07 January 2006 at 4:27 PM
~bookmark~
