Wed, Dec 4, 4:24 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 04 4:13 pm)
Subject: Poser 5 and animation issue
szymas ( ) posted Mon, 09 January 2006 at 10:11 AM · edited Wed, 04 December 2024 at 4:13 PM
When I render or make movie, the textures on my characters (hair, clothes, etc) don't come out. Yet if I render a single frame it works fine... the only thing that I do have is a backgroup picture in the scene.. Any help?
randym77 ( ) posted Mon, 09 January 2006 at 10:42 AM
What render settings are you using? It sounds like you might be using the preview mode. Make sure you set it to Poser 4 or Firefly if you want the textures rendered.
randym77 ( ) posted Mon, 09 January 2006 at 10:47 AM
P.S. If you're using the P4 renderer, make sure "use textures" is checked.
szymas ( ) posted Mon, 09 January 2006 at 10:58 AM · edited Mon, 09 January 2006 at 10:59 AM
In Firefly it is set to Production and texture maps is checked.. I will try in P4 rendered with textures checked to see if that makes a difference, aslo does p4 render faster in production, I don't need high end res as long as the textures are applied..
Message edited on: 01/09/2006 10:59
randym77 ( ) posted Mon, 09 January 2006 at 11:00 AM
But do you have Firefly selected in the "make movie" settings?
leeloominae ( ) posted Thu, 02 February 2006 at 8:19 PM
Im having the same problem, I have my movie output settings like this: Production / FireFly Renderer / Use displacement maps / Cast Shadows / Smooth Polygons / Use texture filtering / Pixels samples = 3 / Bucket size = 32 / Raytrace bounces = 4 / Post Filter size = 1 / Post Filter type = Box / Render to new windows / Constrain aspect ratio / Render over = black, blah blah (not important ones, i think) I cannot see the hair texture and it doesn't render over black, just the default poser background. What am I doing wrong here? Thanks for any reply!
randym77 ( ) posted Sat, 04 February 2006 at 6:38 PM
You have to choose your render settings in "Make Movie," too. You'll have a choice of "Current Display Settings," "Current Render Settings," or "Current Sketch Settings." You have to make sure "Current Render Settings" is selected. The default is the display settings.
