Tue, Jan 7, 1:40 AM CST
Subject: Lightwave objects to Bryce
vdallas ( ) posted Sat, 07 January 2006 at 6:43 PM · edited Sun, 05 January 2025 at 10:31 AM
I have two .lwo files that will not import into Bryce 5.5. B5.5 simply indicates that an 'unexpected error (invalid format)'.
Is there something else that I'm overlooking... or can do?
No, I do not know what version Lightwave was used.
TIA
Dann-O ( ) posted Sat, 07 January 2006 at 7:26 PM
You need an older version of lightwave. I think Lightwave 5 or earlier. Try a file converter like crossroads to change it or try even another modeler like Wings which is free open it up and export again as an obj. Could also be a spline object too.
The wit of a misplaced ex-patriot.
I cheated on my metaphysics exam by looking into the soul of the person next to me.
wheatpenny ( ) posted Sat, 07 January 2006 at 8:46 PM
Site Admin
What I do is open the lwo in deep exploration then resave it as either an obj or a 3ds.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
CrazyDawg ( ) posted Sat, 07 January 2006 at 11:46 PM · edited Sat, 07 January 2006 at 11:47 PM
Attached Link: http://www.micromouse.ca/downloads.html
you can also use a program called Accutrans to convert it from LWO to obj, 3ds, dfx or one of the ones that bryce will take..You can get it from the link i posted. PS: Read the installation guide as well on the download page.
Message edited on: 01/07/2006 23:47
I have opinions of my own -- strong opinions -- but I don't always agree with them.
vdallas ( ) posted Mon, 09 January 2006 at 11:36 AM
Well, I tried & tried, but I couldn't convert these object files to either .obj or .3ds. I followed everyones advice, but whatever files I produced wouldn't import into B5.5. I followed CrazyDawg advice to use Accutrans to convert it. (Nice program)I even saved each layer as a separate object. Nothing.
Anyway, should anyone like to have a nifty model of an asteroid field follow this link and D/L from the bottom of the page.
http://www.newtek.com/products/lightwave/tutorials/specialfx/asteroid/index.html
And if anyone gets it into Bryce I'd love to hear about it.
wheatpenny ( ) posted Mon, 09 January 2006 at 1:05 PM
Site Admin
When I load those lwo and lws files into Deep exploration, they're blank, with nothing in them.
Jeff
Hablo español
Ich spreche Deutsch
Je parle français
vdallas ( ) posted Mon, 09 January 2006 at 1:22 PM
In Accutrans the asteroids are barely visible, but they are there... many, many small objects. I needed to zoom in.
wheatpenny ( ) posted Mon, 09 January 2006 at 1:34 PM · edited Mon, 09 January 2006 at 1:43 PM
Site Admin
When I load them they come out blank.
I can convert them to 3ds but Bryce loads them as empty, and Vue says it cannot read them. (either 3ds or lwo format) I can see the asteroids in Accutrans, but any attempt to save them results in an unreadable file.
Message edited on: 01/09/2006 13:43
Jeff
Hablo español
Ich spreche Deutsch
Je parle français
vladster ( ) posted Mon, 09 January 2006 at 1:51 PM
The LWO in question cannot be imported into Bryce because there are no faces, only vertices (just like the dynamic hair in Poser 5). The tutorial at newtek is to illustrate an application of HyperVoxels which are a type of metaobject (similar to a Metaball in Bryce) You could get a similar effect using Metaballs and Booleans, but Bryce has no scripting capability at this time so each asteroid would have to be done individually. Another possibility is to make an Lscript in Lightwave to generate randomly sized and placed spheres as a single object and then use displacement and bump maps. Also you could use Terrains in various orientations to generate facades of asteroids (less polygon intensive).
