Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 6:51 am)
If you want to selectively delete get 3DOExplore from senosoft.com Click on the thumbnail of the prop or figure, wait for it to build the tree then you can see what is located where and delete what you want. Remember, I used the term..selecively, you will have to repeat for each item. Pun or Puninstall, can't remember the corret name is another. search the free area for that one.
Attached Link: http://www.blacksmith3d.com/free_poser_stuff.htm
Poser Library Uninstaller You can download it free at Blacksmith3d, scroll to the bottom of their page for the link.Does anyone know if Poser Library Uninstaller puts stuff in your Recycle Bin when you uninstall it? I"m wondering if it does that so I can rezip it and save it after I uninstall something.
A few other tricks, assuming you run Windows XP on that laptop: - run "del *.tmp /s /q" from the command line. It'll remove tons and tons of temporary files that tend to get strewn about your disk. If you have more than one partition, run it from the root folder of each partition. - disable the Recycle Bin. - clear your temporary internet files cache. - disable System Restore. It'll free up a lot of disk space. Works only in WinXP. Last resort, if you do this you cannot return your system to a previous state, even when you reenable System Restore afterwards!
Alas, I have to delete at least two gigabytes of stuff from my beloved laptop before it will even acknowledge the need for a defrag. Most of these are Poser files. Is there a program/utility out there that you can designate, say, a prop and have it find all the connected files, let you select which ones to toss out, and delete those from your hard drive? It would help greatly if it were free and came with "idiot friendly" instructions. Thanks for everyone's help! Tony O
