Fri, Nov 15, 3:23 PM CST
Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
Subject: Light? trouble? glass-masters come in please
Markusthaman ( ) posted Mon, 09 January 2006 at 1:02 PM · edited Wed, 23 October 2024 at 9:14 PM
Hey everyone. i got a major problem. i have downloaded some city buildings from here, but when i render the images or the material images the glass on the objects turn black. i change the material to other type of glass/mirror, but it wont turn shiny/reflective or anything. just black. anyone know what could have gone wrong? please let me know if you know. =) thanks a lot
Markusthaman ( ) posted Mon, 09 January 2006 at 1:32 PM
actually everything turns black, the moment its a biny bit of reflective.. this is maybe a eastier thing to find out of. i dont know. anyone does?
bruno021 ( ) posted Mon, 09 January 2006 at 2:03 PM
What did you download? Would be easier if we knew know what you're talking about.
Markusthaman ( ) posted Mon, 09 January 2006 at 2:16 PM
its not just download. its everything that have a reflective surface. if i want a aliminium surface, and turn on reflectivity it just turn black. =/ i have no clue what it is
wabe ( ) posted Mon, 09 January 2006 at 2:28 PM
Can you provide us with an example maybe? Something to examine, a sphere maybe with a reflective surface. This would be most effective probably.
Markusthaman ( ) posted Mon, 09 January 2006 at 2:40 PM
OK. this is my settings. i have not edited the material. just clicked "mirror" at a sphere, and then ok http://www.home.no/markusthaman/Vue/sphere.JPG now. this is the render. i have still done nothing.. JUST clicked the render button http://www.home.no/markusthaman/Vue/sphere2.JPG you see what i mean now? lol i dont have a clue what it is at least.. =/
bruno021 ( ) posted Mon, 09 January 2006 at 2:52 PM
Now this is weird. From the render I can see you use Infinite, could you tell us which version you're using? Built & patch? The only idea that comes to my mind is that in the render settings, "enable sub rays" is disabled, thus not computing reflections. Which quality did you render this sphere? Was it the default "preview" or was it "sketch"? If the latter, it's normal, sketch doesn't compute reflectivity or transparency. If it is something else, I'll let wabe help!
Markusthaman ( ) posted Mon, 09 January 2006 at 3:20 PM
it were prewiev. but i have recently rendered a 1600x1200 with GI with the same results.. so its all over. i use the latest build from e-on i think checking build 275925. ill try the "enable sub rays" and ill come back and reply..
Markusthaman ( ) posted Mon, 09 January 2006 at 3:24 PM
the sub rays are on.. so i dont have a single clue (no more then be4) whats going on. anyone knows? sigh
bruno021 ( ) posted Mon, 09 January 2006 at 3:47 PM
built 275925 is an old one, maybe you should try downloading latest patch 279784.
Polax ( ) posted Mon, 09 January 2006 at 3:49 PM
You should check in render options if 'Force use reflexion map' is checked. If so uncheck it or change the default reflexion map which is 1x1 black pixel. Hope that helps
Markusthaman ( ) posted Mon, 09 January 2006 at 3:53 PM
oh.. well. the update button says im all updated lol. i download at e-onsoftware.com? or can i download somewhere else?
Markusthaman ( ) posted Mon, 09 January 2006 at 3:57 PM
oki. ill try that.. thanks for reply. 2 secs.. checking W00T! it workzored! thanks a lot. =) clearly i hont have a clue at anything in vue lol.. thanks a lot. =)
jc ( ) posted Mon, 09 January 2006 at 5:38 PM
Good call Polax - that was a pretty tough one!
