Wouldn't adjusting the atmosphere's haze do that? You don't mention which version of Vue you use, but you can probably set the altitude and depth of haze and/or fog and adjust the colors to match the sky too. _jc Art-Head-Start.com Art training e-book for digital artists and students. Free chapter on lighting.
JC, just tried to adjust fog and haze but they don't interact with starlight at all. I used several different settings (white fog/haze, black fog/haze, red, blue etc.) with different values of altitude and depth and it didn't change anything. Except for the foreground, that is. The only thing I can do is blending off starlight completely if I pull the fog up to maximum, but that blends off everything else, and that's not exactly what I was thinking of ... Even worse, I also noticed that starlight doesn't interact with clouds either. Whether I use a clear sky or one full with clouds, I always see the same number of white, shiny stars :o( Oh, and I'm using V5Infinite with the latest backups.
Not so good :o( I haven't used stars, except in clear night skys. How about making your own stars on a vertical alpha plane in front of the camera? You could then make them with a variable erasure or gradient mask in Photoshop (so they fade near the bottom)? Probably good to put in a feature request at e-on for stars with more control (at their "Feedback Center").
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=1131577
Hello out there. I'm quite new to vue and was just working on a picture with a rather light evening sky. I added some stars and reduced brightness to about 10%, but unfourtunately Vue doesn't fade their light down as they come closer to the (bright) horizon as you would see it in nature. Does anyone know a trick to do it anyway (not in postwork but in vue)?For anyone who wants to see my problem, I post a link to the pic. As you can see, the stars are always white, no matter whether they are high up in the sky or down at the horizon.
