Sun, Jan 26, 3:27 PM CST
Subject: Creating a bodysuit for a morphed Vicky
DocMatter ( ) posted Sun, 18 March 2001 at 6:22 PM ยท edited Sat, 25 January 2025 at 12:00 PM
I'm tring to create a bodysuit for a highly morphed Vicky but am having a helluva time doing it. I tried using the grouping tool and the heirarchy editor, but I obviously don't know enough (and the manual doesn't say enough) about them to be any good. Any suggestions?
morganza ( ) posted Sun, 18 March 2001 at 7:19 PM
I've created a body suit for my character, it took me a while to understand what i was doing, i'll try and explain it as best i can: the grouping tool is your best friend! using the grouping tool you will have to select individual body parts> select new group> add all> assign material> and then create a name for it like "leather" or "suit" and make sure it is spelled right each time you add a new body part. i've spent hours redoing the entire body just because of a lack of focus. This process will take around an hour, but it is the only way i know of, take your time with it. I hope this helps a little, Morgan
morganza ( ) posted Sun, 18 March 2001 at 7:28 PM
This is what i did...
PhilC ( ) posted Sun, 18 March 2001 at 7:58 PM
If you are just assigning new material names to individual body parts then another way is to:-- Load the file into UVMapper.
  • Edit/select by group and select all the body parts you want to change.
  • Now Edit/assign and give them all a new material.
  • Save the OBJ with a new name.
  • Edit the figure CR2 to point to this new OBJ.
The grouping tool will work, and may be the best way if only sections of a group are required, but I think you will find this method quicker for a body suit.
DocMatter ( ) posted Sun, 18 March 2001 at 8:20 PM
I'm not sure if I'm doin it right Morganza. I went through all the steps you described (and created props along the way). But when I finished and applied a texture to it, parts of the body were sticking through. What I'm trying to do here is create a body suit that I can apply a texture to for my morphed Vicky, but I want to be able to shrink the bodysuit so that a different texture on Vicky's body shows through. This is all done in animation. What am I doing wrong?
morganza ( ) posted Sun, 18 March 2001 at 9:00 PM
My friend, If you want to create a bodysuit clothing prop, then i would ask the master "PhilC", i'm sure he would be happy to help you. Creating clothing is beyond me, i,m still learning the ropes.
