Carrara F.A.Q (Last Updated: 2024 Sep 07 1:44 am)
Great tutorial Litst, it'll be even better when its finnished tho in the third bit of the first part were u talk about "Once you have your profile, continue to add vertices using the same technique." what exactly is the same technique? do u rotate slightly add some vertices to the profile then rotate abit more then add more vertices and so on? It could just be me, im not the smartest person at the best of times. Keep up the good work, I think this tutorial will be a huge help to alot of us, who currently struggle with the mesh modeller. ...FATfoe out :P
litst - One word... Awesome. Nice work. I'm going to give it a whirl this weekend as well. Thanks so much for taking the time to do the tutorial. Regards, Clint
Clint Hawkins
All my life I've been over the top ... I don't know what I'm doing
... All I know is I don't wana stop!
(Zakk Wylde (2007))
Thanks for your comments ! Once i find a way to model ears efficiently, i'll update the tutorial . In fact, making this tut is a good way to optimize my techniques ! :) Fatfoe, what i meant by "continue to add vertices using the same technique" was in fact : "continue to add vertices using the 'v' key " . I know my french speaking isn't the better way to explain something in english ! ;) So continue to ask if you stick on something ! litst
Attached Link: http://www.chez.com/litst/tut/tutintro.htm
I've been working on a modelling tutorial lately . Even though it's still unfinished, you can check it at the attached link . Please comment and ask if there is something that sounds unclear to you ! litst
