Sun, Jan 12, 3:46 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 11 8:46 pm)
Carrara Free Stuff here.
Subject: Carrara / Poser question
SmallFry ( ) posted Fri, 13 January 2006 at 4:52 PM · edited Sat, 11 January 2025 at 11:38 PM
Is it possible to apply Poser poses or facial expressions to it a Poser figure after it's been imported into Carrara?
Dizzi ( ) posted Fri, 13 January 2006 at 5:33 PM · edited Fri, 13 January 2006 at 5:37 PM
Yes, see image. (You'll have to select the Body actor of the figure first, to get the dialog).
Import pose will import all kind of poses (regular, hand, face). If you happen to use a PC, you may want to try my Poser Library Browser. The latest betas can copy files to predefined folders so you don't have to browse with Carrara itself (just open from the folder the file you double clicked was copied to :-))
Message edited on: 01/13/2006 17:37
SmallFry ( ) posted Fri, 13 January 2006 at 8:27 PM
Thanks, Dizzi! Will I have to import the Poser figure using Carrara's Import feature or with TransPoser? Does it make a difference?
Dizzi ( ) posted Sat, 14 January 2006 at 3:38 AM
This works only with the native importer. Carrara doesn't get any bone information when importing via Transposer, so it can't apply poses to the figure (as it doesn't even know body parts).
SmallFry ( ) posted Sat, 14 January 2006 at 12:55 PM
Thanks, Dizzi!
AndyCLon ( ) posted Fri, 20 January 2006 at 11:07 AM
I had trouble importing very large pose files that I'd generated using Mimic, don't know if anyone else has seen this? (using latest .2 patch)
ren_mem ( ) posted Sat, 21 January 2006 at 11:16 PM
Let me check.
No need to think outside the box....
    Just make it invisible.
