Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 26 9:02 am)
The image I posted above was done long before the RDNA toon sharders came to be. So it seems like it's possible to do it without them.
Message edited on: 01/13/2006 19:50
say." - Ghandi
Thanks Fatale :) I'll give the math node a try.
Nancy, I know it's possible in post work, but I've seen several black and white renders that have a small hint of colour to the lips or eyes in the MP, and I don't think they were all done in photoshop, so it seemed to me that it must be possible to do in Poser. EDIT: Raven, thanks for that screenshot. I'm still new to the node aspect of the material room, so that helps me a great deal.
Message edited on: 01/13/2006 20:23
say." - Ghandi
Attached Link: http://www.gimp.org
failing that..this is 'the poor man's Photoshop', which does have some B&W filters as well..I know, I know, it's Postwork, but a little won't hurt..;)I wish I'd said that.. The Staircase Wit
I do have Photoshop 6, but prefer Paintshop Pro which is what I use, so the graphic program isn't a problem if I want to do it in post work, but I don't, hehe I'm lazy and I don't like post working stuff if I can avoid it, and prefer to do what I can inside Poser.
I'm one that is forever searching for that elusive "make art" button ;)
Message edited on: 01/13/2006 20:35
say." - Ghandi
say." - Ghandi
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=1044639
There is a "poor man's trick" for these people who don't know how works the most of the Poser6 nodes (thanks, Fatale and Raven, you just make me the day :D ). Take the textures you want to use, do a copy, in Photoshop or another retouch software convert it in b/w image, save and apply to your figure. I did this when I don't knew about the existence or use of hsv node Doc Geep, would be possible a tut? "All the P6 nodes and what does each one"
CASETTE
"Poser isn't a SOFTWARE... it's a RELIGION!"
Thanks :) I'll keep that tip in mind. But I'd still like to know how to do it within Poser without having to resort to using another program to achieve the effect. It is possible because I just went through the MP and came across very many black and white promos with coloured lips and/or eyes, so it is possible. I doubt very much that they are all using Photoshop and rehuing their textures or renders. I've sent off PM's to a few merchants and hope they will share with me what they did to get their black and white renders.
say." - Ghandi
Monochrome film doesn't have a linear colour response, and blue tends to be brighter than red. But then the photographer uses a colour filter to cut back on the bluer light. But RGB colour doesn't really have the spectral resolution, the commonplace yellow (anti-blue) filter doesn't cover the same range of colours as the blue channel. If you have the colours distinct enough, you can probably select the lips in Photoshop, invert the selection, and convert the selected area (now not the lips) to greyscale. Photoshop Elements came with my film-scanner and certainly has the features to turn colour images into something close to black-and-white film, even adding grain effects.
I would definitely echo Dizzi's math_function route. The advantage of using it is that, as deisred, you retain the detail of the texture map plugged into value 1 without using any of the colour. Also, it's something you can vary between material groups - you want to highlight hte red lipstick worn by the vamp character? not a problem, just leave the maths_function out of the lips material area. I've yet to check on whether a strongly coloured light affects the materials and colours the final results, but should this be the case, I'm working on a method of working out various coloured light's equivalents in greyscales, so as to use them and avoid having a red light on a black and white cartoon (although I can simulate the luminosity of a red light, if you see what I mean). friendlyrogue
Attached Link: http://inkulator.sourceforge.net/
There's also Inkulator, a separate renderer which attempts to emulate pen-and-ink.Content Advisory! This message contains nudity
Obviouly, I did not apply this treatment to the lips.
The interesting idea here, is that one can combine get the details from a texture map, but stay in B/W mode without modifying the texture.
::::: Opera :::::
Operaguy, that's what I'm looking to do!!! Would you mind posting a screenshot of your material room settings/nodes? Locating them isn't a problem, figuring out where to plug them in and in what order is something I have a problem getting my head around.
say." - Ghandi
Yes, the lights need to be neutrally coloured. Since photographs aren't always pure black in their tones, you can put a very slight tint in the light. Sepia toning is the most obvious example (the silver in the print is replaced with another metallic compound), but there are other more subtle ways of getting a more stable print. A very slight touch of blue, for instance. But the effect is actually strongest in the darkest parts of the image, and I can't see how you can do that in Poser. Negative lights? It's a term I've heard somewhere.
Negative lights are what they suggest - 'lights' which actually remove light from an area, a la black holes. If you were to light an area with infint light, for example, then place a negative spot within the scene, then there would be a lovely splat of darkness in your otherwise illuminated scene. So this isn't the way to go, I think... Regarding using lights. I did a little test file up in Photoshop, using the basic three circles of primary colour and desaturating the thing afterwards, to find out the relative luminosities of different coloured light. Would this b of help to anyone who wants to give their images the look that they've been coloured, without actually using colour in the lights (if that makes sense?) jonthecelt (formerly friendlyrogue)
Quote - I did a little test file up in Photoshop, using the basic three circles of primary colour and desaturating the thing afterwards, to find out the relative luminosities of different coloured light. Would this b of help to anyone who wants to give their images the look that they've been coloured, without actually using colour in the lights (if that makes sense?)
Yes, I would be interested :) To me light is the most important element in a scene and it can make or break your image. Anything that can help make good lighting, is of extreme value :) I'd love to see what you came up with and how you did it etc.
say." - Ghandi
Ok, got another solution re: the lighting... and it's easier, and requires no outside files/software. If you have a lot of lights in your scene, though, it might take a little time.
Set up your lighting as normal in the scene - position, type, shadows, colour, the lot. THEN, before rendering, head into the materials room and go through each light in turn. Connect an HSV node to your light's colour setting (don't change the colour yet!). Set 's' (saturation' to 0. Then add a simple_colour node to the colour of the HSV node. Set the colour of the simple_colour node to the light's original colour (simply click the eyedropper over the original swatch). NOW, go back to that original colour setting and change it to white. TRhis will give you a perfectly desaturated greyscale light, with the correct values for the colour you desire...
glad I worked through this one... been meaning to give it a crack for a while.
jonthecelt edit If any of you has Shader Spider, by Poseworks, I can offer a FX6 file for greyscaling out all the texture information for your models, if it helps. and if you don't have ShaderSpider, may I recommend the free version, ShaderSpider LE, which allows you to use FX6 files, if not create them yourself?
Message edited on: 01/15/2006 13:59
Attached Link: http://market.renderosity.com/mp/SoftgoodImage36015c.jpg
Is it possible to render in black and white?I've been seeing commercials for "Sin City", which is primarily black and white with a small hint of red here and there. Is that possible to do in Poser 6?
I just saw a banner for something in the MP that is like what I'm referring to.
How do you do that in Poser?
