Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
Attached Link: http://www.gardenhose.com/groups/new_winter.jpg
An easier way is to simply use Ctrl+L to select the "nozzles" from within the nozzles directory on the CD. Of course, loading files from a CD is slow so you may want to copy the Nozzles folder to your HD and load them from there.You should probably avoid using the Nozzle Library feature in Painter now because it tends to distort the images whereas loading the nozzles individually isn't nearly as destructive. Here's a brief explanation: http://www.gardenhose.com/P6Fix.htm
If you care to contact me off list, I can send you login info that will give you access to updates and tutorials. That applies to any DigArts customer here who hasn't received our recent tutorial/freebie/update emails. Send to info@gardenhose.com
Speaking of winter trees freebie nozzles, there are several small demonstration versions (freebies) available for download. Nice for winter backgrounds and stuff. They're at http://www.gardenhose.com/treelines.htm Use the demonstrations link.
PS. DigArts is a commercial site. If you find that offensive, please don't follow these links.
I realize this is a poser area, and I left a message in the Painter area, but Painter has 6 new messages, and Poser has over 500 new messages. That being the case I hoped someone here might be able to help. I have 'Digarts Garden Hose v,2, and Garden Hose 1,5', that were for Painter 5. There is a label that says they are Jungle CD-R disks. I bought them some time ago and now that I purchased Painter IX I'd like to use them, But I'm confused about installing them. I hope someone can help.
