Thu, Jan 16, 11:43 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 15 2:13 am)
Subject: Pupil (eye) Question
DuBetzDesigns ( ) posted Sat, 21 January 2006 at 12:20 AM ยท edited Thu, 16 January 2025 at 11:35 AM
I am trying to replace the normal "black" pupil with a shape. Meaning, I need to go from round to star shaped. Everytime, however, the pupil renders with the shapes color and will not display the shape, it remains round. I've tried making a seperate pupil texture mat and pointing the PZ2 to it but the result(s) are the same. How can I successfully change the shape of the pupil? I appreciate your time. Using Poser 6, Windows PC
lmckenzie ( ) posted Sat, 21 January 2006 at 2:24 AM
I guessed trans map and that was wrong so no idea. Even a spawned pupil prop does the same thing. Something about the way they're mapped perhaps? I think I've seen it done so hopefully someone will wander by with the (probably simple) answer :-)
DuBetzDesigns ( ) posted Sat, 21 January 2006 at 3:25 AM
What about "Cat-eyes", how are those done?
Jules53757 ( ) posted Sat, 21 January 2006 at 3:25 AM
Try the groupng tool. First delete the polygons for your new shape from the pupil and then add a new group with the deleted polygons. Now you can add a texture to this new material group.
Ulli
kirwyn ( ) posted Sat, 21 January 2006 at 3:30 AM
I think I would morph the pupil very small, if that is possible, and put the star shape texture on the iris.
eirian ( ) posted Sat, 21 January 2006 at 3:53 AM
Which figure are you using? The Unimesh line has some iris morphs but I don't think there's a star. The "Eyez" (at RuntimeDNA.com) are detailed eye models compatible with most of the popular figures, and they include an iris you can transmap to any shape you like. There were a couple of add-on texture sets that included some really whacky iris transmaps, I know there were several stars included. But that's a pay-for product; if you're looking to do this yourself I think Kirwyn's suggestion is probably the way to go: edit the iris texture you're using.
jonthecelt ( ) posted Sat, 21 January 2006 at 7:35 AM
If your desired pupil shape is larger than the area grouped on the eyeball for the pupil, then there's no way you can get all the material info into that group - it simply ignores the area outside of the circle. So the best bet would be to use the transmap/texture map you've designed on both the iris AND the pupil, allowing for spill from one to the other. I'd also advise using a transmap as well as the texture, and if you really want to get funky, then find a way to colour the inside of the yeball red - to give you that funky retinal look! jonthecelt
lmckenzie ( ) posted Thu, 26 January 2006 at 11:55 PM
I think jonthecelt is right. You could try grouping the iris and pupil together and spawning a "contact lens" smart prop. Hopefully, if you position it just in front of the eye it might work.
