Sat, Feb 8, 7:24 PM CST
Subject: Legacy File Writer
Netherworks ( ) posted Mon, 23 January 2006 at 11:26 AM · edited Sat, 08 February 2025 at 7:24 PM
Attached Link: http://www.netherworks-studios.com/nws-utility.htm
![tnLegacyFileWriter.jpg](http://www.netherworks-studios.com/Freebies/tnLegacyFileWriter.jpg)
Legacy File Writer is a Python script for Poser 5 and Poser 6 that will take nearly any existing Poser library file (more appropriately Figures (cr2), Props (pp2), and Hair (hr2) ) and write a Legacy file version (Poser ProPack and Poser 4).
This is for folks who like many of the features of Poser 5 or 6 but would rather have files that are more backwards compatible. It can also be a very useful merchant resource. This script accomplishes the following:
  • It will write a new library file with "-P4PP" at the end of the filename so your original stays intact.
  • Removes ControlProp declaration completely, including heirarchy lines.
  • Removes Dial Groups information.
  • Removes ShaderTree information.
  • Removes other P5/P6 specific information like backface culling, shading rate, polygon smoothing and so on.
  • Writes version number as 4.01
  • Coverts absolute to relative paths in texture and object declarations
  • removes the mostly useless "Preview" material.
  • Attempts to remember the last directory used as personally, that annoys me to no end in Poser. :)
Limitations:
In order to create proper legacy files, it is up to you to set appropriate program settings, such as turning off file compression and external binary morphs in Miscellaneous preferences. It is doubtful that the script will work with such things and it remains untested.
The script also writes a configuration file (to Runtime:Python:poserScripts), which saves the last directory used so hopefully you won't have to fight with that annoyance frequently. However, some file operations in Poser, like adding things "on the fly" to the python library may set the last directory to your scripts directory. I haven't completely worked that out yet.
xantor ( ) posted Mon, 23 January 2006 at 12:48 PM
Thank you.
Gareee ( ) posted Mon, 23 January 2006 at 12:58 PM
Actually, it'd be nice to be able to togel on and off what you'd like the file to be saved at does. Having something rewrite the obj and texture correct paths, and just change version to 4.01, and then resave as the P5/6 version would be nice. (Can't recall how many hours I've spent double checking and redoing things like that.)
Netherworks ( ) posted Mon, 23 January 2006 at 1:01 PM
That would be nice :) Feel free to alter the script if you'd like to.
Netherworks ( ) posted Mon, 23 January 2006 at 1:18 PM
Actually, I was going to edit this, but my "time limit" was up - er, um okie dokie. so I'll just add: Actually, there are few sections that could easily just be commented out. I pretty much annotated everything. I could write, or cut down a version to save a P5 file with the "corrections".
SWAMP ( ) posted Mon, 23 January 2006 at 1:32 PM
This will be good for people still(prefer) using ProPack to get rid of the "newer version of Poser" error messages pop-ups. Thanks...very nice of you. SWAMP (Chuck)
Tyger_purr ( ) posted Mon, 23 January 2006 at 1:52 PM
I just need something to cut the Center of Mass props out. could this script do just that?
My Homepage - Free stuff and Galleries
krimpr ( ) posted Mon, 23 January 2006 at 2:28 PM
Thanks Netherworks!
TrekkieGrrrl ( ) posted Mon, 23 January 2006 at 4:00 PM
Thanks! What a great idea!
Netherworks ( ) posted Mon, 23 January 2006 at 4:50 PM
Okay, Okay, I'll set up the script with checkbox options Just because I luff yew. :)
DCArt ( ) posted Mon, 23 January 2006 at 4:53 PM
We love you too! LOL Thanks so much! I've been wishing for one of these. 8-D
BillyGoat ( ) posted Mon, 23 January 2006 at 5:45 PM
Absolutely Wonderful!!!!
Netherworks ( ) posted Mon, 23 January 2006 at 11:23 PM
Almost done :) Poser File Re-Writer coming. Gives you checkbox options for everything that the Legacy File Writer does. So you can just remove the control prop, or just the shader trees, or the control prop and the Preview material, and and and... ;)
Netherworks ( ) posted Tue, 24 January 2006 at 5:17 AM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=2554537
Gareee and Tyger thank you for your suggestions :)
Tyger_purr ( ) posted Tue, 24 January 2006 at 8:28 AM
your awesome.
Netherworks ( ) posted Tue, 24 January 2006 at 2:40 PM
I even got the right files in the right zips today! LOL!
Gareee ( ) posted Wed, 25 January 2006 at 11:01 PM
No, Thak YOU for making the changes! We are only as good as the tools we use...
