Fri, Nov 8, 4:51 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Nov 05 6:06 am)
Carrara Free Stuff here.
Subject: Use SSS for skin
sslide24 ( ) posted Mon, 23 January 2006 at 11:35 PM · edited Fri, 08 November 2024 at 4:45 AM
How tune values in parametrs SSS for create real skin shader?
steama ( ) posted Tue, 24 January 2006 at 12:48 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=106&Form.ShowMessage=2547513
This post by Shonner may help you.
ren_mem ( ) posted Tue, 24 January 2006 at 3:41 PM
There is also a preset in the program to help. Depends on the shader tho so it will vary.
No need to think outside the box....
    Just make it invisible.
ShawnDriscoll ( ) posted Tue, 24 January 2006 at 4:38 PM
The preset is great if you're doing renders of embryos. But for adult humans that have more mass to them, turn the intensity down to around 25-30% for starters. And for GI renders, use just a 10% white background as light for the scene (or a 90% black background as light) so you don't blow out your human with radiation. SSS makes them very sensitive to outdoor light.
sslide24 ( ) posted Wed, 25 January 2006 at 1:56 AM · edited Wed, 25 January 2006 at 1:57 AM
2 SHONNER please write value of SSS parametrs what you apply in this image http://www.renderosity.com/photos/MSG2/Message2554342.jpg
Message edited on: 01/25/2006 01:57
ShawnDriscoll ( ) posted Wed, 25 January 2006 at 2:22 AM
ShawnDriscoll ( ) posted Wed, 25 January 2006 at 9:33 PM · edited Wed, 25 January 2006 at 9:35 PM
I forgot to tell you that those settings are for a 5'8" - 6' tall figure. They may not work for just the head of a figure.
Message edited on: 01/25/2006 21:35
enigmaticredfrog ( ) posted Thu, 26 January 2006 at 10:50 AM
it's more or less a trial and error. and I change my sss between characters from time to time depending on the look I am going for.
Christina -- "Love me but don't tell me so" Lilly Bart
My Art
ShawnDriscoll ( ) posted Thu, 26 January 2006 at 11:09 AM · edited Thu, 26 January 2006 at 11:14 AM
Just remember that the SSS settings are global for a scene. They are not local for an object's shader channel. So when you change the size of an object, you have to re-adjust the SSS settings for it. The bigger the object, the more you'll want to increase the SSS refraction index setting. Reduce it for smaller objects.
Message edited on: 01/26/2006 11:14
enigmaticredfrog ( ) posted Thu, 26 January 2006 at 11:16 AM
thanks... I didn't know that. (ignorance is bliss)
My Art
ShawnDriscoll ( ) posted Thu, 26 January 2006 at 11:43 AM
I didn't know it either, until I read up on SSS theory and application and saw that they were doing stuff globally. I found a couple sites that used Max 8 that had a radius setting for their SSS. I don't think Carrara has that in their SSS.
ren_mem ( ) posted Sat, 28 January 2006 at 12:24 AM
So how come you can select an ear(shader domain) sss setting differently than a head? What's the point?
ShawnDriscoll ( ) posted Sat, 28 January 2006 at 2:25 AM
Attached Link: http://www.lamrug.org/resources/doc/sss-skin-tutorial.pdf
I guess you would need to as a work-around to make up for not having a SSS radius setting in Carrara. I wonder if Poser 6 has more (or less) SSS settings than Carrara? I'm curious if Carrara can do a SSS ear as well as the PDF tutorial shows?
