Tue, Nov 26, 8:59 PM CST
Subject: Some Poser stuff not working in Vue Infinite..
meselfr ( ) posted Sun, 22 January 2006 at 2:36 PM ยท edited Sat, 23 November 2024 at 5:34 AM
We should start a list of Poser products that do not function properly in Vue... I have run into a few products lately that either don't display properly when imported or just don't load at all... Recent examples: Listurne Hair (Doesn't load at all) M3 Space Suit (sun visor is white, and cannot be changed...) Any ideas or workarounds would be greatly appreciated... Poser6.0.2, Vue Infinite Build 279784 Cheers/Thanks.
jc ( ) posted Sun, 22 January 2006 at 4:23 PM
"M3 Space Suit (sun visor is white, and cannot be changed...)"
Can't be changed in Poser before import? Or can't be changed in Vue after import?
Guess you've seen the many posts about Poser highlights being black, etc. and needing edits in Poser before import?
Sorry, i don't have more ideas...
_jc...'Art Head Start' e-book
.......Art Head Start.com site
Art knowledge and skills for digital artists. Free chapter on lighting, Vue tutorials and models.
meselfr ( ) posted Sun, 22 January 2006 at 4:27 PM
After import... it renders white, no matter what I do... as for the listurne hair.. I put it in it's own PZZ and after loading there is no object... no errors... :) Yes.. I mess with the highlight color/strength a lot to get the look I want and the bumps don't come over cleanly, and some items that use ERCs or switching geometry don't load properly... but these are weirder than the weird.. THanks... mes
Dale B ( ) posted Sun, 22 January 2006 at 7:30 PM
This helmet? The materials can be changed just fine in my tests (In fact they have to be, as all of them come out of Poser opaque to begin with) Don't mess with the list in the world pane; look at the texture list in the material window for your actual materials to swap. Your problem may be in the fact that you have everything compressed. In the Python window, there is a series of utility scripts; one of them decompresses all your content, so that you have pz3's and all other resources are P4 compatible...which is a lot more compatible at the moment than P6 is. The ERC and switching geometry -may- be related to you using external morphs. Infinite still doesn't know what a .pmd file is (and won't until EF gets them a new SDK that explains it for Vue).
jc ( ) posted Sun, 22 January 2006 at 8:06 PM ยท edited Sun, 22 January 2006 at 8:07 PM
Great info Dale B. Bit over my head as a Poser newbie. Would be winderful if you could do a tutorial on these Poser importing tips/techniques!
Or maybe you know of one?
Message edited on: 01/22/2006 20:07
hein ( ) posted Mon, 23 January 2006 at 3:40 AM
All of my Poser imports into Vue5 d'E have material issues, Vue replaces all maps with a default and refuses to change them. The mat editor shows that the right maps are loaded but replaces them in the scene with a default mat(Mirror in most cases), if I look in the Mat Summary all materials look the same, when I click "edit" I can see that the correct mat is loaded.
My only workaround at the moment is to import the Poser into Vue4, save and then import the file into Vue5, this however requires me to have 2 PC's running, one with the whole Poser set-up and Vue4 and one with the same Poser setup and Vue5. Would be nice if Vue 4 and Vue 5 would run on the same PC.
niandji ( ) posted Mon, 23 January 2006 at 4:38 AM
I have had Vue 4.2, Vue 5 Esprit, Vue Infinite and Vue Easel all running on the same PC, so I don't think that is a general issue.
meselfr ( ) posted Mon, 23 January 2006 at 4:07 PM
I don't have a problem importing most stuff into vue... however if it has PP mat files I always choose those over a p5/p6 mat file to ensure no issues... but it's just weird... BTW Dale_B I tried your suggestion, and I still couldn't change the color... It's white... hit F6 and go into the material editor... changed it to one of the gold presets... still white... oh well... mes
Trelawney ( ) posted Tue, 24 January 2006 at 5:03 PM
Hi Try the following with materials that import incorrectly: - Open the Material from F6 Material Summary - Go to the effects Tab and try setting Color Reflected Light(Metallic) to 100% - Got to the Reflection tab and try dropping Global Reflectivity to 0% - In the Colour Tab, try unchecking Colour Blend checkbox These can be tried individually or in combination - but often work well for me :) This was a quick test using the same M3 Spacesuit, but I forgot to open the faceplate as Dale did above (better example than mine btw!) Kind regards Roderick Davies
meselfr ( ) posted Tue, 24 January 2006 at 5:19 PM
darn... that looks awesome.... Let me give it a try... Thanks for the help..
Phantast ( ) posted Wed, 25 January 2006 at 5:05 AM
The mirror problem is straightforward - any material in Poser that is reflective usually comes out as mirror finish in Vue and has to be edited. Especially if it had a reflection map in Poser. It's a pain.
