Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 02 9:25 am)
Back way back I used to put noise on my textures to give the illusion of blueness under the skin. From time to time I use blue instead of warm color setting with RealSkinShader. Try also maybe making the lips more warmer or putting some little blush on the cheeks to emphasis the translucency. This image looks washed out with too bright light maybe. I use a couple bluish and greenish spot lights not too bright. I don't know if your specular is too high but sometimes you want that so... Darkening and texturing the eye socket below the eye also gives both contrast and the illusion of thinner pigmentation in the skin... these are old painters tricks... contrast contrast contrast. Warm skin against cold hair and cold skin against warm hair, the problem in pigment painting is punching contrast given the limitations of the materials.
Attached Link: Good as Dead
the best way I found to get realistic looking pale skin is to start off with a healthy looking skin texture and then slowly bring down the saturation. If a texture gets too pale, then you will loose all the little details and it will end up looking flat. If you are going for a vampiric quality then the skin add some underlaying veins and use the burn tool to accent certain areas where whatever remaining blood may be still visible (like eyes joints, nails etc.) My ultimate pale vamiric skin is in my "good as dead" texture set (at daz), where my "undead" character has skin so glassy you can also see muscle and other things along with the veins under the skin. but you may not want to go that pale LOL Rawn (RawArt)Thanks for the input Rawnrr. I was hoping to achieve the whole underlying veins peeking thru the skin type thing. But, I just can't get it to look like healthy natural white skin. Like Momodot said above, it does look washed out. Sorta flat and boring with no life. I'm going to try all the tips I've received and hope for the best along with my basic trial and error.
I know plenty of real people who have "alabaster skin" - very white. Usually with either blue or pink undertones.
Such a complexion can be very difficult to reproduce in a satisfactory, realistic-looking way in Poser. Much like very dark skin is also difficult to get to look right in Poser. The extremes on either end of the spectrum are problematic.
My own solution usually consists of fooling around with the lighting until it looks right. Simple, but it works.
Message edited on: 01/24/2006 17:42
Attached Link: Maskedit Texture
If you want to spend some money and use someone else's texture the pale texture in this package linked above is phenomenally luscious. The promo doesn't do it justice at all. Just beautiful.I always wondered about the old days when they described a woman's skin as milky white. Went to a strip club one night and this dancer had exactly that, milky white skin. It wasn't veiny looking or even pale. It had a glow that was special....its even hard to describe. Perfect , soft, smooth, white
Humankind has not
woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound
together.
All things connect......Chief Seattle,
1854
Attached Link: http://market.renderosity.com/mod/bcs/index.php?ViewProduct=24776
One of my favorite white textures for V3 comes with the CLUB character for V3 by elementbs.Great character, too.
Uh-oh.....she's "no longer available for purchase". Too bad.
I use Poser 4, so obviously my meathods are a little more primative than yours; however, I read a tutorial here in poser some time, in which the writer advocated changina the ambience of th eskin tone from shadea of black to shades of 'Russet'. He did this by setting the three primary values to: 10, 100, 10.
He said, that when rendering, this would lend an aura of living, breathing flesh to the shadowing of the skin.
Other aspects of Alabaster skin I would factor in through Highlight and Color.
Message edited on: 01/25/2006 02:31
Attached Link: http://www.fortunecity.com/rivendell/lucky/472/happyworldlanduncut/pages/p4_woman_02.htm
Dear momodot: Here is a P4 china white skin texture.STOP PALESTINIAN CHILD ABUSE!!!! ISLAMIC HATRED OF JEWS
Thank you @Kendra. I'm not sure what the hair is called; but if you say it's sapphire fox, then let it be so. I took it off one of the Eve's by Arduino -the one wearing the leather bustier, spike heels, and holding a horse whip in a ratheragressive manner. As I'm not a mosochist, I assgned her hair, bustier, and heels to my prop section, and her to oblivion. I think th ehair suits Eve 4 quite nicely.
