Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 10:35 am)
The reason I ask is becasue I have P6 and Photoshop open, and I'm editing Eye textures, in photoshop, and then trying to test thier results in Poser, but I see Poser must have the MAT pose textures I've applied cached somewhere, becasue when clear the nodes, re-save the texture maps, and then reapply the MAT pose, I'm still getting the origional texture?
I hope you checked "Keep Textures Loaded" is off, right? Also try the menu item "Reload Textures"
Both menu items are near the bottom of the "Render" menu. It's actually nice to have "Keep" checked because loading the textures is the first step in a render and can take a while. Be keeping the previously loaded texture files in memory, poser can skip that step when you render the same scene over and over, messing with lights and what not. You want to turn it off in when, as you are doing, you are changing the file contents between renders.
I just searched for a Clear Nodes .PZ2/.PY, but only found P5 stuff. I DL'd them, and give it a whirl, but not all the nodes cleared?
