I don't know anything about Poser 4 and ProPack, but so far as I know in Poser 5 and Poser 6, a "bump map", is a grey scale image and they aren't created in the material room.
I'm playing in the material room now and trying to figure out what the different nodes do, and found that if you connect your 2D image map to a math node and then connect that math node to "Bump" on the poser surface "window" (not sure of the proper name), that you kind of end up with a bump map of sorts. Playing with the number in the "Bump" will give different degrees of bumpiness/texture.
Otherwise I think you have to go to your graphic program, convert to grey scale and then resave it out as (name)BUMP.jpg from what I've seen inside my texture folder.
I am still learning the material room, so it's possible I'm missing something, so before going into a spin of panic, hehe, wait for someone else to reply who has more knowledge of that room than I do.
Message edited on: 01/29/2006 05:18
say." - Ghandi
Hello: I updated from Poser 4 to Pro Pack just this morning, so certain aspects of it are new to me. One of them is a quandery with bump maps. I open the materials menue and load a .jpg file for use as a bump map, and instead of converting it to a .bum file, Poser now loads the .jpg directly. is this proper, or is something wrong with my Poser? Any advice will be appreciated.
