Tue, Nov 26, 6:08 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 5:46 am)
Subject: Sketch Rendering, any good id
DarkEden ( ) posted Thu, 22 March 2001 at 7:40 AM ยท edited Fri, 22 November 2024 at 12:02 PM
I'm trying to make the sketch renderingen working in Poser 4 but it's so hard.The result i want is that i take a character that i make and render it into a sketch figure. Like when you draw it with a pen but in poser. Does anyone know of any good tutorials or levels to make it look more like a drawing then a 3d picture. Thanks DE
thip ( ) posted Thu, 22 March 2001 at 10:39 AM
If it doesn't have to be done within Poser, try this.
Cybermonk ( ) posted Thu, 22 March 2001 at 11:03 AM
Just a tip on using the sketch render, turn off all transparencies. They really mess up the final results. Other than that all I can sugest is just play with it. Use a simple model to get the settings right then save them and load up your more complex stuff for a try. This way you dont spend so much time waiting on the results. Hope this helps
____________________________________________________
"The true sign of intelligence is not knowledge but imagination".
Albert Einstein
bloodsong ( ) posted Thu, 22 March 2001 at 12:09 PM
heyas; did you try the cartoon and lined cartoon modes? you can also set the sketch render thingy to do only outlines and not interior shading. i cant remember exactly how that goes, but look at the top for what you are working on (outline, background... and whatever the interior pieces are called).
DarkEden ( ) posted Fri, 23 March 2001 at 2:33 AM
Thank you for the help ;)
