Just a tip on using the sketch render, turn off all transparencies. They really mess up the final results. Other than that all I can sugest is just play with it. Use a simple model to get the settings right then save them and load up your more complex stuff for a try. This way you dont spend so much time waiting on the results. Hope this helps
____________________________________________________
"The true sign of intelligence is not knowledge but imagination".
Albert Einstein
heyas; did you try the cartoon and lined cartoon modes? you can also set the sketch render thingy to do only outlines and not interior shading. i cant remember exactly how that goes, but look at the top for what you are working on (outline, background... and whatever the interior pieces are called).
I'm trying to make the sketch renderingen working in Poser 4 but it's so hard.The result i want is that i take a character that i make and render it into a sketch figure. Like when you draw it with a pen but in poser. Does anyone know of any good tutorials or levels to make it look more like a drawing then a 3d picture. Thanks DE
