Fri, Jan 24, 1:10 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Subject: Help on uploading images
cole4965 ( ) posted Wed, 01 February 2006 at 8:36 AM ยท edited Wed, 22 January 2025 at 9:11 AM
I want to post my first images but I keep getting an error message that the thumbnail is too big. I try to reduce it in photoshop but the resolution gets so low to reach 15 K that it isn't visually acceptable. Suggestion? Thanks!
gagnonrich ( ) posted Wed, 01 February 2006 at 8:43 AM
If you're using Photoshop, you need to go to Edit/Preferences and uncheck a few things, such as saving a thumbnail and ICC profiles and maybe something else. I don't have Photoshop on this computer, so I can't be more specific. Other things that can be done are reducing the JPG quality or switching to GIF.
My visual indexes of Poser content are at http://www.sharecg.com/pf/rgagnon
SamTherapy ( ) posted Wed, 01 February 2006 at 8:44 AM
Use the Save for Web option. That will reduce the size without massively degrading your image.
Acadia ( ) posted Wed, 01 February 2006 at 2:40 PM
What I do to make a thumbnail is to open a new blank image in the dimensions of the thumbnail (200x200 pixels). Then I copy my gallery image and paste it as a new layer to the blank image and then move the image layer around until I see something I like. I then use "File" and "Export" and pick "jpg" and then adjust the compression to the minimum number that squeaks me just under the 15 kb in size limit. I always end up with a good quality thumbnail doing that.
